Since July 2026, the MOBOTIX M73 FM Bundle has held ANSI/FM 3260 approval as a flame detector. The approval applies to operation in controlled indoor environments. If you know the M73 as a rugged outdoor camera, this may look like a contradiction.
It is not. “Indoor” describes the scope of the FM approval, not the robustness of the hardware. This article explains how FM distinguishes indoor from outdoor applications, where the M73 FM Bundle fits, and what this means for your fire detection projects.
What FM Approval and ANSI/FM 3260 are
FM Approvals is the third-party testing and certification organization associated with the industrial property insurer FM Global. It certifies products for property loss prevention, and FM states that its mark is recognized by leading regulatory authorities worldwide.
Flame detectors that respond to radiant energy are examined according to ANSI/FM 3260 (ANSI/FM 3260-2023). Among other things, the standard requires:
- alarm initiation within 30 seconds of flame exposure
- no false alarm from direct or reflected sunlight, arc welding, electric heaters, or artificial light
- verification of the manufacturer’s claims for fuels, distances, and field of view
- environmental, electrical, and durability tests
The FM approval adds to the existing MOBOTIX fire-detection certification portfolio, which includes EN 54-10, VdS, CNPP, and RIPCI/Applus.
How FM distinguishes indoor and outdoor applications
ANSI/FM 3260 does not grade how rugged a device is. It defines minimum test conditions, and these depend on the intended application:
After each conditioning, the detector must still respond to a test fire with less than 10 % loss of sensitivity and without a false alarm or trouble signal. Detectors intended for temperatures beyond these limits are tested at their specified extremes and marked accordingly. For indoor applications, the standard requires at least an ANSI/UL 50 Type 1 enclosure; any further enclosure ratings the manufacturer claims are verified separately.
Where the M73 FM Bundle fits
MOBOTIX defines the intended use in the M73 FM Bundle guide: the bundle meets the requirements of FM 3260 when it is installed with the specified components and operated in controlled indoor environments, within an operating temperature range of –30 to 65 °C (–22 to 149 °F) and up to 95 % relative humidity, non-condensing.
These limits extend well beyond FM’s indoor test range of 0 to 49 °C. FM’s outdoor category, however, requires testing at –40 °C, which is below the bundle’s specified minimum of –30 °C. The datasheet specifies every bundle component for –30 to 65 °C: the camera, the thermal sensor module, and both interface boxes.
The indoor classification therefore describes the scope of the approval. The bundle’s hardware ratings are IP66, NEMA 4X, and IK10.
What the bundle contains
- Mx-M73A camera, pre-assembled with the thermal radiometry sensor module 640R050 (VGA 640 × 480, 95° × 76° field of view), the MultiSense module, and a blind module
- Mx-F-4IOA interface box with alarm/fault relay (SPDT) and trouble relay (SPST) for connection to a fire alarm control panel
- Mx-F-NPAA PoE injector with 12–24 V DC input
- FM-approved firmware MX-V7.3.6.70-FM or the latest FM-approved release
You can add an optical sensor module, for example for visual alarm verification, without affecting the FM 3260 approval, provided that the thermal sensor module remains in place.
Verified detection distances
According to the MOBOTIX guide, the following distances were verified in standardized tests as part of the FM 3260 approval. They reflect the test conditions and reference fire sizes, not necessarily the technical limit of the system.
The solid fuels were pre-burned for one hour. Detection distance decreases toward the edge of the field of view.
What this means for your FM projects
Inside buildings, the M73 FM Bundle can be used as an FM-approved flame detector. This is relevant wherever insurers, planners, or authorities require FM-approved fire detection equipment.
Suitable applications
MOBOTIX designed the bundle for flame detection in areas with elevated fire risk, naming waste management, recycling, and storage as examples. Typical indoor sites include waste bunkers, recycling halls, warehouses, and industrial halls. For an FM-compliant installation, the site must be a controlled indoor environment within the specified limits.
In these environments, the bundle provides:
- detection of abnormal heat before flames become visible
- up to 20 independent measurement areas per camera, plus exclusion zones for known heat sources
- alarm and fault signals to the fire alarm control panel via the Mx-F-4IOA relays
- optional visual verification with an additional optical sensor module
The apps MxAdvancedRadiometry and MxThermalValidation are optional and require a separate license (30-day trial included). Their use in an FM project depends on the specified use case and is subject to acceptance testing by the independent auditor.
Requirements for an FM-compliant installation
The datasheet and the guide name these requirements:
- Use only the specified bundle components and original MOBOTIX parts.
- Run FM-approved firmware.
- Protect the entire flame detection system, including cameras and alarm systems, with a UPS or batteries that bridge power outages of up to 72 hours.
- Use an FM 3260-compliant power supply; the PoE switch must provide PoE Plus (IEEE 802.3at-2009), Class 4.
- In areas exposed to heat, use fire-resistant cables or fire-resistant cable conduits.
- Carry out and document the commissioning tests described in the guide, and repeat inspection and maintenance every six months.
Your responsibilities
The FM approval confirms that the product met the standard under the tested conditions. It does not replace project-specific approval. Installers and operators remain responsible for planning, installing, configuring, and maintaining the system in line with the applicable standards and with any local authority or insurer requirements. MOBOTIX recommends that only qualified, MOBOTIX-certified professionals carry out these procedures. ANSI/FM 3260 refers to NFPA 72 for wiring methods, so check early which codes apply to your project.
What does not change
The FM approval adds a verified use case to the M73 FM Bundle. It does not change the hardware:
- The housing ratings remain IP66, NEMA 4X, and IK10, and the specified operating range remains –30 to 65 °C.
- Use outside an FM-compliant fire detection system is governed by the datasheet and, where applicable, by other approvals.
- Other M73 thermal bundles, such as the M73 EN54 bundles, are separate products with their own specifications and approvals. The indoor scope described here applies to the M73 FM Bundle only.
When the FM scope applies
The decision path below shows when the indoor scope of the FM approval matters for your project.
The indoor scope is relevant only when a project requires FM compliance. In all other cases, the datasheet and the applicable approvals govern how you use the bundle.
FAQ
Is the M73 no longer an outdoor camera?
The hardware ratings are unchanged: IP66, NEMA 4X, and IK10. The indoor scope applies only to the FM 3260 approval of the M73 FM Bundle as a flame detector.
Can I install the M73 FM Bundle outdoors as an FM-approved flame detector?
No. FM 3260 compliance applies to controlled indoor environments within the specified limits. If you are planning outdoor fire detection, contact MOBOTIX early to discuss which product and approval fit your project.
What counts as a “controlled indoor environment”?
At a minimum, the site must stay within –30 to 65 °C and 95 % relative humidity, non-condensing.
Can I add an optical sensor module?
Yes. An additional optical sensor module does not affect the FM 3260 approval, as long as the thermal sensor module remains in place.
Can I update the firmware?
Only FM-approved firmware releases keep the installation within the approval. ANSI/FM 3260 requires every software change to result in a new release level and prohibits modifications beyond the examined state. Check the latest FM-approved release before updating.
Can the bundle be used in hazardous locations?
No. According to the MOBOTIX guide, the product must not be used in potentially explosive atmospheres.
Do I need the optional Camera Apps for the approval?
The MOBOTIX AdvancedRadiometry App and MOBOTIX ThermalValidation App are optional. Whether you use them depends on your use case, and their use in an FM project is subject to acceptance testing by the independent auditor.
Further information
The technical specifications and the M73 FM Bundle guide cover installation, commissioning tests, handover documentation, and maintenance in detail. Both are available in the MOBOTIX Download Center under Marketing & Documentation.
If you have questions about FM projects do not hesitate to contact your MOBOTIX partner or your MOBOTIX sales representative.
