1. Overview & Purpose
In mission-critical video surveillance, healthcare environments, and industrial facilities, uninterrupted camera operation is essential. A common operational challenge occurs during network switch reboots, firmware upgrades, or local network infrastructure maintenance, which results in temporary loss of Power over Ethernet (PoE).
All camera models within the MOBOTIX ONE platform feature built-in hardware support for simultaneous dual-power connections via Power over Ethernet (PoE) and an external 12–24 V DC auxiliary power supply. This design delivers zero-downtime power failover and high system reliability in demanding deployments.
2. How Dual-Power Redundancy Operates
When both power sources (PoE and external 12–24 V DC) are simultaneously wired to a MOBOTIX ONE camera, the internal hardware power management controller coordinates the power paths autonomously without requiring user configuration or software settings.
Operational Switching Behavior:
- Normal Operation (PoE + DC Connected): PoE acts as the dominant power source. The camera actively draws operational power through the Ethernet interface (RJ45), keeping the 12–24 V DC line in an energized standby state.
- PoE Failure / Network Switch Maintenance: If PoE voltage drops or disconnects (e.g., switch reboot, port power-cycling, or cable disconnection), the camera seamlessly switches to the 12–24 V DC input.
The camera continues operating, streaming, and recording without undergoing a reboot cycle or losing volatile status data. - DC Power Interruption: If the external DC line drops or loses power while PoE is active, the camera continues operating completely unaffected on PoE power.
- PoE Power Restoration: When PoE returns to the network port, the camera automatically reverts to PoE as the dominant power source without interrupting video streams or rebooting.
3. Power State & Failover Matrix
| Primary Source (PoE) | Auxiliary Source (12–24 V DC) | Active Power Load | System Status & Camera Behavior |
| Active | Active | PoE (Dominant) | Standard operation. Auxiliary DC line is held in hot-standby. |
| Fails / Disconnected | Active | 12–24 V DC | Seamless failover. Camera does not reboot. |
| Active | Fails / Disconnected | PoE | Uninterrupted standard operation on PoE. |
| Restored | Active | PoE (Dominant) | Seamless switchback. Automatically returns to PoE dominance without reboot. |
4. Important Engineering & Installation Guidelines
Important Notice: Power Consumer vs. Battery Charging
The 12–24 V DC auxiliary input terminal is strictly a power consumer (load). The camera does not supply charging voltage or act as a battery management system.
If connecting a backup battery system (e.g., 12 V / 24 V lead-acid or lithium battery pack), always route the battery through an external buffer power supply / charge controller before connecting to the camera’s DC input terminals.
Electrical Specifications & Recommendations:
- PoE Standard: IEEE 802.3af (Class 3) / IEEE 802.3at (depending on sensor/module configuration).
- Auxiliary DC Input Range: 12 V DC to 24 V DC (nominal).
- Surge Protection: For outdoor, industrial, or perimeter installations, installing a certified MOBOTIX MX-Overvoltage-Protection-Box on all data and power feeds is strongly recommended.
