MxMC 2.9.4 – c ONE support: Greater security from the very first access
Continuous development of the MOBOTIX security concept
At MOBOTIX, security is not a one-off achievement, but an ongoing development process. That is why we are constantly working to make our cameras and software solutions even more secure against unauthorised access, whilst at the same time making secure commissioning as straightforward as possible for our users.
With MxManagementCenter 2.9.4, we now also support the new MOBOTIX c ONE camera models. At the same time, we are integrating a key enhancement to our tried-and-tested Cactus security concept directly into the setup process.
Why is this extension useful?
Our MOBOTIX partners are well aware of the importance of secure, unique administrator passwords. The relevant recommendations have long been an integral part of our MOBOTIX Hardening Guide and form part of the professional security measures for a video system.
Nevertheless, many integrators are familiar with this situation from real-world experience: during commissioning, there are numerous tasks to be carried out. Cameras must be integrated, network settings adjusted, functions tested and the entire system configured.
It is certainly possible that changing a factory-set password may initially be postponed until a later date.
However, in the hectic day-to-day life of a project, a well-intentioned remark such as ‘We’ll sort that out later’ can quickly become a forgotten security step.
This is precisely where the enhanced Kaktus security concept comes into play.
What has changed?
Previously, changing the factory-set administrator password was mandatory, particularly when accessing a camera via its web interface for the first time. However, depending on the circumstances, it was possible to use a camera via other access methods – such as a video management client – before this step had been completed.
With the new c ONE camera models, this principle has been consistently extended.
A brand-new camera will only enable its standard camera services once the factory-set administrator password has been replaced with a custom password. This applies not only to the web interface but also, for example, to the event stream used by MxManagementCenter.
Changing the password is therefore no longer a security measure that can be postponed until later, but a prerequisite for the normal use of the camera.
What does this mean for MxMC users?
With MxMC 2.9.4, we have integrated these additional security requirements directly into the familiar set-up process.
MxMC automatically detects when a c ONE is still in its protected factory state. New security icons clearly indicate this status.
The integrated Secure System Wizard then guides the user through the mandatory process of setting an individual administrator password and subsequently checks other security-related settings such as HTTPS and Public Access.
In this way, we support our partners in consistently implementing the already well-known and tried-and-tested security measures – without any additional organisational effort and without the risk of overlooking a crucial step during commissioning.
The result: enhanced security through an intelligent setup process that actively supports the user and excludes the familiar default password from regular camera operation right from the start.
MOBOTIX is thus demonstrating once again that we do not merely document our security concepts, but continuously develop them further and integrate them directly into our products.
Step by step: Setting up a new c ONE in MxMC 2.9.4
In the following example, we use a brand-new MOBOTIX c ONE to demonstrate how to carry out a secure initial commissioning.
1. Find the camera
Open the Component View and use Camera Discovery to find the camera.
A c ONE in its factory-set state is displayed with a new lock icon with three asterisks (***).
This symbol indicates the specific initial state of the enhanced Cactus security concept.
2. Add a camera
As usual, use drag-and-drop to move the camera you have found from Camera Discovery into the project’s camera list.
3. Note the yellow padlock icon
Once added, the camera appears in the left-hand navigation bar with a yellow padlock icon.
This indicates that the mandatory initial password setup has yet to be carried out.
4. Start Secure System
In the Component View, open the Secure System Wizard for the relevant camera.
MxMC recognises that the camera has not yet been fully secured and guides you through the next steps.
5. Set a new administrator password
Tick the “Change camera factory default password” option.
Then set and confirm a new administrator password.
The password must be at least 8 characters long. You can find information on the permitted characters via the Info icon in the dialogue box.
Note: When accessed for the first time, the statuses displayed for HTTPS and Public Access may still be incomplete. MxMC can only read the full camera configuration after the initial password has been set.
6. Confirm password change
Confirm your entry by clicking OK.
Once the password has been successfully changed, the yellow padlock icon will disappear from the camera list.
The camera now uses a unique administrator password.
7. Automatic repeat security check
After approximately 20 seconds, the Secure System Wizard reappears.
Why a second time?
Only after the password has been changed can MxMC read and verify the camera’s full security configuration.
In doing so, MxMC detects, for example, whether:
encrypted HTTPS should be enabled;
Public Access is disabled.
If necessary, the required settings can now be adjusted directly via the wizard.
8. Complete the security check
Confirm any necessary changes by clicking OK.
After a short wait, MxMC will confirm that the security check has been completed successfully:
“The selected camera is secure.”
The result: Secure right from the very first access
With MxMC 2.9.4, the secure initial commissioning of a c ONE is integrated directly into the familiar camera workflow.
The user can immediately see if a camera still needs to be initialised and is guided step-by-step through the necessary procedures.
This prevents the default factory administrator password from being reused during regular commissioning or from being forgotten when it needs to be changed.
Find the camera, add it, set a password, check the security status – done!
