I have a MOVE-BC1A-4-IR IP camera - onvif Profile G compliant, I’ve set it up to record on the SD card, the playback rtsp url i got through onvif to play back my recordings was (rtsp:///playback?recordingtoken=O1) but it fails to play with the rtsp error (Stream not found), I wonder how can I playback my recordings using RTSP ?
your help is much appreciated
Thank you
