T26 and Fanvil i506W integration issue
Hi Mobotix Community
For about the last year the T26 Door Camera and a Fanvil i506W have been working well together.
Someone presses the ring button on the T26 and audio/video are transferred the Fanvil station.
Now it has just stopped working. Nothing was changed on it. We are having a hard time getting the two devices to communicate with each other. Getting timeout or 501 error code on the fanvil.
Does anyone have experience with setting up a fanvil as a door station for the T26?
Hi,
since the setup worked reliably for about a year and, according to your description, nothing was intentionally changed on the T26 or the Fanvil, I would first ask one central question:
Has anything changed in your network since then?
For example:
  • were new devices added?
  • was the router replaced or reconfigured?
  • did the DHCP configuration change?
  • did either the T26 or the Fanvil receive a different IP address?
  • could there be an IP address conflict with another device?
If both devices receive their IP addresses via DHCP, I would first verify the current IP addresses and compare them with the SIP configuration.
Another important point:
Which device is currently acting as the SIP server / registrar?
Is it
  • the router / PBX,
  • or the T26 itself?
That determines where the Fanvil should register and which SIP address/port needs to be used.
A firmware change on the MOBOTIX camera can normally be excluded unless somebody updated it manually, as MOBOTIX cameras do not perform automatic firmware updates.
For the Fanvil i506W, however, I would still check the currently installed firmware version and whether it may have changed.
Please also try a SIP test call from the T26
The T26 can initiate a SIP test call to the configured Fanvil destination.
Please run this test once and let us know exactly what response or error message the camera reports.
That is very useful because it separates the SIP communication itself from the normal doorbell/event logic.
If the SIP test call already fails, we can focus directly on:
  • network connectivity,
  • SIP registration,
  • IP address/port,
  • routing,
  • firewall/NAT,
  • or SIP compatibility.
If the SIP test call works but the normal doorbell call does not, then the problem is more likely in the event/call profile configuration rather than in the basic SIP connection.
The timeout indicates that a SIP request was sent but no usable response came back.
The 501 response means that the receiving SIP endpoint did answer, but did not support the requested SIP method or function in that form.
My troubleshooting order would therefore be:
Network changes / DHCP / IP conflict → identify the SIP server → SIP test call from the T26 → check Fanvil firmware → check SIP registration → inspect T26 system messages
If you can post the result of the SIP test call together with the current IP addresses and the relevant T26 system messages, the problem should be much easier to narrow down.
In general we have Community users who has experience with Fanvil , may they have further ideas:
Best regards
Jörg
Hello Mx-JoergS
Thank you very much for your helpful reply. I am new at this since the tech who knows a lot more than I do, left the company, and this was placed on my desk. I am hoping I can find someone new to help take care of things like this. Either internally or outsource it.
From what I can see, nothing has changed in the last year. No devices added, there was no router change that I know of, IP address do not appear to have changed. I do have an email out to the end users IT department to see if anything changed on the firewall side. But I am going to dig deeper in this area.
The T26 acts as the registrar/sip server.
I do not recall what the fanvil firmware was a year ago. I don’t think it has been upgraded. I am not sure how to check that. Do you know how to check that?
Please remind me on how I do a sip test call on the T26. Thank you
My apologies for not knowing this information. I am new at this, and I still have a lot to learn.
Thank you
Jeff
TCS
Hi Jeff,
Thanks for your feedback and for checking with the IT department!
Since the T26 acts as the SIP registrar/server and the setup has been working for quite some time, I would first concentrate on the network configuration. I wouldn’t expect the camera’s SIP settings to change on their own without any configuration changes.
Even if nothing has intentionally been changed, it would be worth double-checking the current IP addresses and SIP settings.
1. Check the IP addresses and SIP registration
Please verify the current IP addresses of both the T26 and the Fanvil i506W.
In particular, check that:
  • The SIP server/registrar address configured in the Fanvil still matches the T26’s current IP address.
  • The T26’s outgoing call profile contains the correct SIP extension or destination for the Fanvil.
  • The Fanvil shows its SIP account as registered.
If DHCP is being used, it is worth checking whether IP addresses have changed or whether there might be an IP address conflict.
2. Check the Fanvil firmware version
I’m not very familiar with the Fanvil devices myself, but according to the Fanvil i506W documentation, you can check the installed firmware version in either of these ways:
  • On the Fanvil device: Menu → Status
  • Through its web interface: Open the Fanvil’s IP address in your browser, log in and navigate to System → Information. The software version should be displayed there.
It would be helpful to know which firmware version is currently installed.
3. Test the network connection directly from the T26
The camera has a built-in network test:
  • Open Admin Menu → Test Network Configuration.
  • Enter the Fanvil’s current IP address in the General Test field.
  • Click Connect and check the result.
This allows us to verify whether the T26 can reach the Fanvil over the network.
You can find a step-by-step example of this network test in the following Community article:
Since the T26 itself is the SIP registrar, there is no separate SIP server that needs to be pinged.
4. Make a SIP test call from the T26
We also have a Community troubleshooting article that explains this procedure with screenshots:
In short:
  • Go to Admin Menu → Outgoing Calls Settings.
  • Select the existing outgoing call profile for the Fanvil.
  • Click Test.
Does the Fanvil ring? If not, what feedback or error message does the camera provide?
The result will help us determine whether the problem is related to SIP registration, network connectivity or the doorbell call configuration.
I would start with these checks before changing any SIP settings or updating firmware.
Please let us know what you find, especially the current IP addresses, the Fanvil’s registration status and the result of the SIP test call.
If you would prefer some hands-on assistance, you are also welcome to contact our MOBOTIX Sales team at sales@mobotix.com. They can help you get in touch with an experienced MOBOTIX partner or, if you are a MOBOTIX partner yourself, explore support options through our MOBOTIX Professional Services.
This way, you can get assistance from someone familiar with MOBOTIX SIP configurations who can help you troubleshoot the setup directly.
Best regards,
Jörg
Hi Mx-JoergS
Thank you for your very helpful step by step reply. It made it a lot easier for me to understand. I do appreciate it very much.
Here is what I have found out. My answers are below in green.
Thank you for taking the time to help me out. I am very grateful.
Jeff
He Jeff
there is nothing mention in “green”?
May you share the infos again in the community!
bye Jörg
Good Morning!
I am not sure why my answers did not show up in green. I am glad to send it again so others can see as well. I will highlight my answers using the words in capital letters
“MY REPLY”. I did not see an easier way to show my replies
  • The SIP server/registrar address configured in the Fanvil still matches the T26’s current IP address. MY REPLY:The IP address in Fanvil Matches the T26 IP.
  • The T26’s outgoing call profile contains the correct SIP extension or destination for the Fanvil. MY REPLY: Outgoing call profile contains correct sip extension and destination
  • The Fanvil shows its SIP account as registered. MY REPLY: This one has me stumped. The vendor agent I got both the T26 and Fanvil from is working on this also. He had made some other changes (I am not sure what yet), and when he made the line account “inactive”, and we had the end user do a test, it worked. Yet if we activiate the line account on the Fanvil, it shows a 501 error code and does not work. How could a P2P work if there is no registration? The only thing I can figure is that the camera vendor has a platfom where the camera and the fanvil both are registered to via open vpn. The platform allows us to monitor the cameras, access them, program, ect.
  • Through its web interface: Open the Fanvil’s IP address in your browser, log in and navigate to System → Information. The software version should be displayed there. MY REPLY: Firmware is 2.12.51
  • Click Connect and check the result. MY REPLY: It looks like it is connecting OK. Here is what I received back.
Registration of a MOBOTIX Camera to an External SIP Provider Getting started
Registration to External SIP Provider [External_SIP_1] Often it’s important that the MOBOTIX Door Station notifies remote clients in case someone rings the doorbell or in case of alarm. However not in all the installations it’s possible to count on an IP-PBX connected to the public network through a trunk line (PSTN and/or VoIP). In the following example we will show you how to create a VoIP account with a public SIP Provider and setup the Door Station to register to it and make calls. With t…
4. Make a SIP test call from the T26 MY REPLY: I need to coordinate a time with the end user as I am working remotely and I need to make sure someone is at their office. Is there a way for me see remotely if the fanvil is ringing or not?
Hello Jeff,
Thank you for your detailed feedback and for sharing the results of your tests!
I think we should take another look at the original situation.
Your T26 and Fanvil i506W had been working together successfully for approximately one year. Pressing the doorbell button initiated a SIP call, and audio and video were transmitted correctly.
Then the communication suddenly stopped working, although, according to your initial description, nothing had been changed.
We can also assume that neither device performed an automatic firmware update or changed its SIP configuration by itself.
For reference, the firmware versions are:
  • Fanvil i506W: Installed 2.12.51 — latest available 2.12.55
  • MOBOTIX T26: Installed version not yet confirmed — latest available MX-V5.4.10.5
Now we have learned that communication works again when the SIP line account on the Fanvil is disabled.
This indicates that direct SIP peer-to-peer (P2P) communication is no problem between the two devices, without registration to an external SIP server.
My main question is therefore how the original installation was configured.
If the T26 and Fanvil were previously communicating through an external SIP server or a SIP service provided by your vendor, and neither IP addresses nor device configurations have changed, we should investigate what may have changed in that external service or in the connection to it.
Possible causes could include network or router changes, VPN connectivity, SIP server availability, or changes made by the service provider.
Other possibilities worth checking are the system date and time on both devices or an expired SSL/TLS certificate, particularly if secure SIP communication or a VPN-based service is involved.
These are potential causes, not confirmed explanations for the reported SIP 501 error.
If the direct P2P connection now works reliably and provides all the required functionality, there is no reason not to continue using it.
As I am not very familiar with the Fanvil-specific configuration options, I would recommend consulting your vendor or the Fanvil support community if further adjustments to the Fanvil SIP accounts are necessary.
Alternatively, you could also configure the MOBOTIX T26 itself as the SIP server.
In this configuration, the Fanvil would register directly with the camera, and no external SIP server would be required for local communication.
We have two useful articles in our MOBOTIX Community explaining this configuration:
How to – Integrating standard SIP clients into a MOBOTIX camera’s internal SIP server
Adding a VoIP phone to a T24/T25/T26 door station
My recommendation would be to first clarify with your vendor whether the original communication depended on their external SIP platform and whether anything changed there.
If the current P2P solution works correctly and reliably, you can certainly continue using it.
Thank you again for your feedback!
Best regards,
Jörg
