MOBOTIX HUB - LPR Module supports license plates from over 200 countries (Generic)
To find out which license plates are supported by the LPR Module, browse the geographical regions listed below. Further down, you will also find a detailed overview of the supported license plate styles for each location.
Global LPR Coverage
Africa
Asia
Australia
Canada
Europe
Generic
Middle East
Mexico
South America
United States (Alabama- Kansas)
United States (Kentucky- North Dakota)
United States (Ohio- Wyoming)
Starting with the MOBOTIX HUB 2022 R2 release, and in all subsequent versions, MOBOTIX HUB LPR recognizes and displays the license plate styles in the Desk Client. However, this feature is not supported for all countries.
Generic
intada_cm_CDN (CDN)
intada_cm_EU (EU)
intada_cm_USA (USA))
intada_cm_X_AUS (X_AUS)
intada_cm_X_BIC (X_BIC)
intada_cm_X_DG (X_DG)
intada_cm_X_EE (X_EE)
intada_cm_X_EU (X_EU)
intada_cm_X_NR (X_NR)
intada_cm_X_USA (X_USA)
intada_cm_X_XX (X_XX)
Generic
intada_cm_CDN (CDN)
CDN_PE_trailer_since_2013_birthplace_of_confederation
Trailer TLR at the left [307x156mm, black on white, front_and_rear]
ddTdd
CDN_MB_passenger_truck_since_1997_base_plate_blue_bison
First letter C is commercial truck.First letter X is for hire vehicle incl. taxis. First letter P is Public Service. [305x153mm, blue on white, front_and_rear]
Cllddd, Xllddd, Pllddd, lllddd
CDN_NT_truck_since_1991_public_service
Plates in the polar bear shape (with dark feet) tree line to tundra under the Northern Lights. At the bottom is NORTHWEST TERRITORIES. [300x150mm, blue on white, front_and_rear]
PDDDD, PDDDDD
CDN_QC_commercial_since_1989
Quebec above next to a small fleur-de-lys. First letter F = commercial or farm veh. < 3000 kg, No I,O,Q,U used. Faa = ambulance, hearse, towing truck, snow blower, driving school cars and trucks,motor homes > 3000 kg, rental cars,special mobile equipment, government (dominion, provincial and municipal).First letter L = truck farm truck, municipal, federal and provincial truck (all > 3000 kg). First letter R = Trailer, semi-trailer, farm trailer. Since 2007 syntax is Rlddddl. First letter T = taxi. First letter X = Dealers, manufacturers (floater licence plate). [305x153mm, blue on white, front_and_rear]
Ldddddd, Llddddd, Rlddddl, Rlddddd, Fdddddd, Flddddd, Flldddd, Tdddddd, Xdddddd, Tdddddl
CDN_BC_apportioned_since_2010
The flag splits the registration into four-two characters. With a legend APPORTIONED. [305x153mm, blue on white, front_and_rear]
dddddP
CDN_MB_trailer_since_1997
Vehicle class code embossed at bottom centre is TL. [305x153mm, blue on white, front_and_rear]
CLlddd, ClLddd, PlLddd
CDN_QC_truck_commercial_since_2011_electric
Quebec above next to a small fleur-de-lys. [305x153mm, green on white, front_and_rear]
FVEdddd
CDN_NU_passenger_truck_trailer_since_2012
dddddd
CDN_PE_commercial_since_2013_birthplace_of_confederation
ommercial CV at the left. [305x152mm, black on white, front_and_rear]
Cdddd
CDN_NB_passenger_taxi_trailer_truck_since_2009_the_place_to_be
Arcing across the top of the plate is a light and dark yellow band with in the centre New, a red galleon and Nouveau above Brunswick above C A N A D A, all lettering in green. [305x153mm, red on white, front_and_rear]
Hddddd, Tllddd, Lllddd, lllddd
CDN_BC_commercial_truck_since_1985
ddddll
CDN_NL_passenger_trailer_since_2003
Labrador at the upper area in red and the provincial flag at lower center. [305x153mm, red on white, front_and_rear]
Hllddd
CDN_BC_passenger_since_1985
A flag symbol representing British Columbia can be found in the middle of the plate. The words Beautiful British Columbia can be found. [305x153mm, blue on white, front_and_rear]
lllddd,dddlll, lldddl
CDN_BC_commercial_truck_since_2008
The flag splits the registration into two-four characters. With specific prefixes, except where shown as a suffix, and some with a legend. [305x153mm, blue on white, front_and_rear]
lldddd
CDN_SK_commercial_since_1998
A Graphic design of a sheaf of wheat in gold in the center. Land of Living Skies [305x152mm, green on white, front_and_rear]
lllddd
CDN_AB_truck_since_1996_wild_rose_country
Alberta at the top followed by a red rose, and Wild Rose Country at the bottom in blue. [305x153mm, red on white, front_and_rear]
Ldddddd
CDN_BC_apportioned_since_1985
apportioned… (NEEDS description) [305x153mm, blue on white, front_and_rear]
Pddddd
CDN_NS_passenger_truck_since_2012
Nova Scotia 2014 passenger issue. Nova Scotia introduced a facelifted version of the bluenose plate in 2012, removing the outside border from the plate and switching to the narrower Mississippi die set now used by Waldale for several different jurisdictions. These changes were made in the early F series. [300x150mm, blue on white, front_and_rear]
lllddd
CDN_NT_passenger_trailer_commercial_since_2010_spectacular
Plates in the polar bear shape (with dark feet) tree line to tundra under the Northern Lights. At the bottom is NORTHWEST TERRITORIES, and the legend SPECTACULAR at the top. [300x150mm, blue on white, front_and_rear]
Tdddddd
CDN_YT_passenger_the_klondike_since_2011
At the top of the plate is The Klondike in red letter. On the left side is an image of a miner, followed by registration. At the bottom of the plate is Yukon on a blue band. [305x152mm, black on white, front_and_rear]
llldd
CDN_MB_passenger_truck_since_2012_base_plate_black_bison
First letter C is commercial truck.First letter X is for hire vehicle incl. taxis. First letter P is Public Service. [305x153mm, black on white, front_and_rear]
CDN_NB_passenger_taxi_trailer_since_2005
At the top was New, a red galleon and Nouveau above Brunswick above C A N A D A, all lettering in green. Rear plate can be trailer plate starting with T [305x153mm, red on white, front_and_rear]
Tllddd, Gllddd, Hddddd
CDN_PE_passenger_since_2013_berceau_de_la_confederation
Province House at the left, a draped Canadian flag in the lower left, the provincial flag similarly in the lower right, a silhouette map of the province behind the slogan, and flying red maple leaves in the upper left corner area. The fairly-new provincial coat of arms is printed in the center as a hyphen. [307x156mm, black on white, front_and_rear]
dddJA
CDN_NB_passenger_taxi_trailer_truck_since_2011
CDN_SK_passenger_truck_trailer_since_2008
Graphic design of a sheaf of wheat in gold in the center. Land of Living Skies. [305x152mm, green on white, front_and_rear]
dddlll
CDN_NU_passenger_since_2009
The former plates were first issued in 1999 and were coloured white with blue characters and border. At the bottom was the name NUNAVUT and the legend EXPLORE CANADA’S ARCTIC was at the top. [300x150mm, blue on white, front_and_rear]
1ddddN
CDN_PE_passenger_since_2013_birthplace_of_confederation
Province House at the left, a draped Canadian flag in the lower left, the provincial flag similarly in the lower right, a silhouette map of the province behind the slogan, and flying red maple leaves in the upper left corner area. The fairly-new provincial coat of arms is printed in the center as a hyphen. [305x152mm, black on white, front_and_rear]
dddll
CDN_QC_passenger_electric_since_2011
Green Vehicle plates (for electric vehicles); always have a small sticker with a pictogram of an encircled car, in the lovwer left corner. Je me souviens ( I remember). Quebec above next to a small fleur-de-lys [305x153mm, green on white, front_and_rear]
lddVEl
CDN_BC_trade_since_1985_demonstration
Dddddd
CDN_MB_passenger_truck_since_2013_bienvenue
Since 25th February 2013 an alternative optional plate has been available for cars, trucks and farm trucks. A pale blue sky at the top with a green, yellow and blue forest and lake scene at the bottom. The registration is dark blue, and at the top in dark blue is the legend Friendly Manitoba, the dot on the i being replaced by a small red maple leaf. At upper right is a small bison and Bienvenue at the bottom in dark blue. [305x153mm, black on white, front_and_rear]
dddddP
CDN_AB_passenger_since_2010_wild_rose_country
Since May 1991 only a rear plate has been required. Alberta at the top followed by a red rose, and Wild Rose Country at the bottom in blue. [305x153mm, red on white, front_and_rear]
llldddd
CDN_NL_passenger_taxi_trailer_commercial_since_2007
Newfoundland above Labrador at the bottom in blue; a small red pitcher plant grows out of the name. [305x153mm, blue on white, front_and_rear]
lllddd
CDN_NL_passenger_since_2003_veteran
Labrador at the top. These passenger plates could also be issued with the national flag and Veteran at the bottom. [305x153mm, red on white, front_and_rear]
lllddd
CDN_NB_truck_since_2009_the_place_to_be
Pllddd
CDN_NB_truck_since_2005
At the top was New, a red galleon and Nouveau above Brunswick above C A N A D A, all lettering in green. Lnn heavy trucks. [305x153mm, red on white, front_and_rear]
Ldddddd
CDN_NT_passenger_since_1986_explore_canadas_arctic
Plates in the polar bear shape (with dark feet) tree line to tundra under the Northern Lights.At the bottom is NORTHWEST TERRITORIES, and the legend EXPLORE CANADA S ARCTIC at the top. [300x150mm, blue on white, front_and_rear]
dddd, ddddd, dddddd
CDN_PE_apportioned_since_2013_birthplace_of_confederation
Prorated vehicles had registrations on this base starting at P-3200 and with PRP in the upper right corner under the national flag. [305x152mm, blue on white, front_and_rear]
Pdddd
CDN_AB_trailer_since_2010_wild_rose_country
dllddd
CDN_NS_passenger_truck_since_1991
At the top of the plate is the province name, and at the bottom the legend CANADA S OCEAN PLAYGROUND. The registration is of three serial letters and three numerals superimposed on a schooner (the Bluenose ) in two shades of blue; these were first issued in June 1989 starting at BRT 001 and will eventually supersede the former series. Older registrations from the 1979 series can be remade with the Bluenose base. [300x150mm, blue on white, front_and_rear]
lllddd
CDN_NB_prorate_truck_since_2011
Pllddd
CDN_YT_passenger_the_klondike_since_1991_small_space
On the left side is an image of a miner, followed by registration. At the bottom of the plate is Yukon on a blue band. Yukon Territory 1992 passenger issue. [305x153mm, black on white, front_and_rear]
llldd
CDN_NS_truck_prorated_since_2004
Pro-rated reciprocity. from 1993 to 2004 the PR plates had the legend OPEN FOR BUSINESS at the bottom, since 2004 the legend has been APPORTIONED. [300x150mm, red on yellow, front_and_rear]
PRddddd
CDN_NS_truck_prorated_since_1993
Nova Scotia 2014 passenger issue. Nova Scotia introduced a facelifted version of the bluenose plate in 2012, removing the outside border from the plate and switching to the narrower Mississippi die set now used by Waldale for several different jurisdictions. These changes were made in the early F series. [300x150mm, red on yellow, front_and_rear]
PRddddd
CDN_NS_trailer_since_1993
Nova Scotia 2014 passenger issue. Nova Scotia introduced a facelifted version of the bluenose plate in 2012, removing the outside border from the plate and switching to the narrower Mississippi die set now used by Waldale for several different jurisdictions. These changes were made in the early F series. [300x150mm, black on yellow, front_and_rear]
Tdddddd
CDN_MB_private_trailer_since_2012
Vehicle class code embossed at bottom centre is TL. [203x127mm, blue on white, rear]
ldddl
CDN_NL_truck_since_1982
Labrador across the top. To the right of bottom center was a multicolored logo of a Viking ship against a setting sun and the slogan A World of Difference. [305x153mm, red on white, front_and_rear]
PRlddd
CDN_SK_passenger_truck_trailer_since_2013
The provincial name Saskatchewan is at the top of the plate in a serif typeface, and at the bottom is the slogan Land of Living Skies. In about April 2009 the letters I, Q, U and V were brought into use for the first time. [305x152mm, green on white, front_and_rear]
dddlll
CDN_BC_commercial_trailer_since_1985
dddddl
CDN_YT_municipal_vehicles_since_1991
Commercial and government plates are similar but often with a different legend at the top. [305x152mm, black on white, front_and_rear]
DAldd
CDN_QC_passenger_since_1983
Green Vehicle plates (for electric vehicles); always have a small sticker with a pictogram of an encircled car, in the lovwer left corner. Je me souviens ( I remember). Quebec above next to a small fleur-de-lys [305x153mm, blue on white, front_and_rear]
dddlll, lddlll, lllddd
CDN_SK_passenger_truck_trailer_since_2011
The provincial name Saskatchewan is at the top of the plate in a serif typeface, and at the bottom is the slogan Land of Living Skies. Since July 2004 only rear plates are required. Vehicle class and date stickers were discontinued on 1st November 2012 [305x153mm, green on white, front_and_rear]
dddlll
CDN_YT_commercial_since_1991
Commercial plates are similar but often with a different legend at the top. [305x152mm, black on white, front_and_rear]
Clldd
CDN_YT_trailer_since_1991
At the top of the plate is trailer in red letter. On the left side is an image of a miner, followed by registration. At the bottom of the plate is Yukon on a blue band. [305x152mm, black on white, front_and_rear]
Tddddd
CDN_NU_truck_taxi_since_1999
Pddddl, Pddddd
intada_cm_EU (EU)
EU_twoline_darkonbright
Generic two-line dark-on-bright EU-style license plate. Any string of 3 to 9 characters [0..9,A..Z]. [520x120mm, black on white, front_and_rear]
xxx,xxxx,xxxxx,xxxxxx,xxxxxxx,xxxxxxx,xxxxxxxxx
EU_singleline_darkonbright
Generic single-line dark-on-bright EU-style license plate. Any string of 3 to 9 characters [0..9,A..Z]. [520x120mm, black on white, front_and_rear]
EU_twoline_brightondark
Generic two-line bright-on-dark EU-style license plate. Any string of 3 to 9 characters [0..9,A..Z]. [520x120mm, white on black, front_and_rear]
EU_singleline_brightondark
Generic single-line bright-on-dark EU-style license plate. Any string of 3 to 9 characters [0..9,A..Z]. [520x120mm, white on black, front_and_rear]
intada_cm_USA (USA)
USA_license_plate_bright_on_dark
Generic USA license plate. Any string of 3 to 7 characters [0..9,A..Z]. [305x152mm, white on black, front_and_rear]
USA_license_plate_dark_on_bright
Generic USA license plate. Any string of 3 to 7 characters [0..9,A..Z]. [305x152mm, black on white, front_and_rear]
X_AUS_bright_on_dark
X_AUS_bright_on_dark [372x135mm, white on black, front_and_rear]
X_AUS_dark_on_bright
X_AUS_dark_on_bright [372x135mm, black on white, front_and_rear]
Container_code
Standard BIC container code [302x152mm, black on white, front_and_rear]
llll dddddd d
X_DG_Dangerous_goods_plate
Orange dangerous goods plate. [400x300mm, black on white, front_and_rear]
dd/dddd, ddd/dddd, Xdd/dddd, Xddd/dddd
X_EE_twoline
Generic two-line dark-on-bright EE-style license plate. Any string of 3 to 9 characters [0..9,A..Z]. Supported countries are AL, BIH, BY, MD, MK, MNE, RUS, RKS, SRB, VY. If the country could not be identified, the country code will be X_EE. [264x205mm, black on white, front_and_rear]
X_EE_singleline
Generic single-line dark-on-bright EE-style license plate. Any string of 3 to 9 characters [0..9,A..Z]. Supported countries are AL, BIH, BY, MD, MK, MNE, RUS, RKS, SRB, VY. If the country could not be identified, the country code will be X_EE. [520x120mm, black on white, front_and_rear]
X_EU_singleline_brightondark
X_EU_twoline_brightondark
X_EU_singleline_darkonbright
X_EU_twoline_darkonbright
X_NR_singleline_brightondark
Generic single-line bright-on-dark number-only license plate. Any string of 2 to 7 digits [0..9]. [520x120mm, white on black, front_and_rear]
dd,ddd,dddd,ddddd,dddddd,ddddddd
X_NR_twoline_brightondark
Generic two-line bright-on-dark number-only license plate. Any string of 2 to 7 digits [0..9]. [520x120mm, white on black, front_and_rear]
X_NR_singleline_darkonbright
Generic single-line dark-on-bright number-only license plate. Any string of 2 to 7 digits [0..9]. [520x120mm, black on white, front_and_rear]
X_NR_twoline_darkonbright
Generic two-line dark-on-bright number-only license plate. Any string of 2 to 7 digits [0..9]. [520x120mm, black on white, front_and_rear]
X_USA_license_plate_bright_on_dark
X_USA_license_plate_dark_on_bright
Standard_plate
Standard plate. Any string of 3 to 10 characters [0..9,A..Z]. [520x120mm, any on any, front_and_rear]
xxx,xxxx,xxxxx,xxxxxx,xxxxxxx,xxxxxxxx,xxxxxxxxx,xxxxxxxxxx
Standard_square_plate
Standard square plate. Any string of 3 to 10 characters [0..9,A..Z]. [300x200mm, any on any, front_and_rear]
