Hanwha Plugin for MOBOTIX HUB
For improved use and interaction with Hanwha devices in MOBOTIX HUB.
Hanwha Plugin for MOBOTIX HUB (formally AI Camera Plug-in) enables a better interaction with the Hanwha devices and MOBOTIX HUB. In addition to searching AI metadata like in previous versions, the plugin now allows control of camera and intercom functions in Desk Client and Management Client.
Key features
- Supports AI camera search based on object attributes (like the previous AI Camera Plug-in)
- Camera special function management (Wiper, Heater, Spinning dry, Auto focus)
- Receive and answer calls from the Hanwha TID-600R Intercom along with unlocking the door.
- Access the web page of Hanwha cameras from within MOBOTIX HUB Management Client application (based on the stand alone Wisenet Camera Configuration plug)
- Share metadata detection between thermal and non-thermal channels.
- Hanwha Plugin for MOBOTIX HUB
- MOBOTIX HUB VMS
How it works:
User can set event category and search with several filters.
Receive and answer calls from the TID-600R in Desk Client.
Access the call history for the TID-600R intercom
Access the camera web UI within the Management Client
How to install:
The follow Install Guide from Hanwha explain the installation steps on a Milestone VMS system ,but the steps can be used similar in the MOBOTIX HUB.
Installation proofed by MOBOTIX QA with the follow versions:
- MOBOTIX HUB 2025 R1
- Hanwha PlugIn Version 1.07.00_250618
