Jpeg Image header contents
SECTION FINGERPRINT Interpretation
VER=1.0 Version of Header, currently always 1.0
PRD=MOBOTIX Product Name
FRM=583466 Running frame counter since last reboot
DAT=2011-04-11 Current Date
TIM=15:13:36.936 Current Time
TZN=EST Time Zone
TIT=1302498816.936 Unix Timestamp with Milliseconds ref:www.epochconvert.com
ENO=309 Event Number
7IMT=IMAGE Image Type - possible is IMAGE (live image, pre- and post-alarm), CLIP or EVENT (for event image)
ENDSECTION FINGERPRINT
SECTION IMAGE
CTY=DUAL Chip Type (Dual or Mono camera)
TZN=EST Time Zone
TIT=1302498816.936 TVo: Unix Timestamp with Milliseconds ref:www.epochconvert.com
ENO=309 TVo: Event Number
ICC=MxPEG Codec used
ICB=12288 internal use only
FRJ=94TVo: Current framerate achieved (9.4 fps)
FRB=166 Maximum framerate achievable, depends on configuration (16.6 fps)
XTO=640 Image Width
YTO=480 Image Height
QLT=60 JPEG Quality
CAM=RIGHT Left or Right Sensor, Selected Camera Image - RIGHT LEFT BOTH PIP)
DPM=SIMPLE,SIMPLE Display Mode for right and left eye
WIN=lt=0,0:rb=639,479:cam=0:flags=fp:v=137 internal use only
VLG=0 internal use only
YPR=0:0:0,0:0:0 internal use only
ZOM=1000,1000 Zoom Level eg. 1000 = 1 x Zoom
PAX=-105,0 internal use only
PAY=206,0 internal use only
SBX=s2b2,s1b1 Image quality setting for X (s1b1=high, s2b2=normal)
SBY=s2b2,s1b1 Image quality setting for Y (s1b1=high, s2b2=normal)
MIR=NONE,NONE Mirror
ROT=0,0 Rotation
ACT=AUTO,OFF Automatic Contrast
SRP=4,4 Sharpness
BRT=0,0 Brightness
BLT=4,4 Backlight Correction
CSA=0,-10 Color Saturation
BBL=0,0 Blue Balance
RBL=0,0 Red Balance
NSM=LOW,LOW Noise Supression
EXW=100,0 Exposure Weighting
WBW=TOTAL,0 White Balance Weighting
AVB=398,0 Average Brightness
AKB=398,400 internal use only
AMB=199,0 Minimum Average Brightness
ACC=0>0,16>0,3582>4080,4080>4080 0>0 internal use only
ACU=0>0,16>0,3636>4080,4080>4080 0>0 internal use only
EXB=5,0 internal use only
GNG=3328,0 internal use only
GNR=4608,0 internal use only
GNB=4096,0 internal use only
GN2=3456,0 internal use only
CUG=1079,0 internal use only
CUR=1070,0 internal use only
CUB=1094,0 internal use only
CU2=1088,0 internal use only
CNG=1075,0 internal use only
CNR=1070,0 internal use only
CNB=1083,0 internal use only
CN2=1083,0 internal use only
BLG=152,0 internal use only
BLR=165,0 internal use only
BLB=168,0 internal use only
BL2=156,0 internal use only
BMG=160,0 internal use only
BMR=176,0 internal use only
BMB=176,0 internal use only
BM2=160,0 internal use only
CCG=1377,0 internal use only
CCR=1421,0 internal use only
CCB=1346,0 internal use only
CC2=1381,0 internal use only
WBG=2150,0 internal use only
WBR=2169,0 internal use only
WBB=2121,0 internal use only
WB2=2133,0 internal use only
WBL=100,0 internal use only
GDG=1024,0 internal use only
GDR=1024,0 internal use only
GDB=1024,0 internal use only
GD2=1024,0 internal use only
EXC=0,0 Exposure Program
EXI=160,0 Minimum Exposure Time in µsec
EXA=160000,0 Maximum Exposure Time in µsec
EXP=21028,0 Current Exposure Time in µsec
ICL=…zh internal use only
ICR=630,0 internal use only
ICE=0,0 internal use only
ICS=5000,0 internal use only
LFQ=50 Line Frequency (50 or 60 Hz)
ENDSECTION IMAGE
SECTION ID
MAC=00:03:C5:03:35:12 Media Access Control address
NAM=mx10-3-53-18 Camera Name
ET0=10.3.53.18 primary ethernet IP access
SWV=MX-V3.5.2.23.r3 Software Version
UPT=41826 Current Uptime in sec
TUP=28025280 internal use only
TSI=10.0.0.181 Time server IP Address
BTM=2 internal use only
CFL=M12D-Sec-DNight Camera Model
TYP=1 internal use only
BRD=1.1 Board Revision Number
RAM=134217728 128 MB RAM 64/64?
USC=SZERIAL JEPG User Comment
CTX=text Serial Message sent to the camera
ENDSECTION ID
SECTION SENSORS
INA=1,HI Signal In A, current state
INB=0,LO Signal In B, current state
INC=1,HI Signal In C, current state
BTR=0 Button Right, current state
BTL=0 Button Left, current state
PIR=1 Passive Infrared, current state from 0…100
LXR=3053 Lux value = x/10
ILR=497 internal illumination value - use LXR instead
TIN=300 Internal board temperature in Degree Celsius (30.0°C)
With GPS-Box Connected in addition:
LXE=64680 illumination in Lux
GPS=49.1445963,9.1870728,5.5 GPS Position
GAL=238,4.5 Height above NN (m)
GVE=0,0.31 Speed (m/s)
GST=18,8 Number of visible, connected Satellites.
ENDSECTION SENSORS
SECTION EVENT
EVD=RUN Arming Switch
EST=vm,uc,br,bl,ci Events Configured: eg. vm,mi,si,si2,si3,si4,pe,uc,bt,br,bl,rc,ci,tp,il,il2,rd,rb,re
AST=EM,IP2,VA,REC,FS Actions Configured
REC=EVNT Recordign Type eg. Event
TIA=2 Before Event Recording Time
TIP=10 Recording Time
SCF=1200 Continuous Recording Frame Rate
SEF=0 Event Recording Frame Rate
MSA=* internal use only
ECT=306 internal use only
ALC=303 Alarm counter
ALM=VM Alarming event(s)
MDT=60 Messaging Dead Time
VAS=HIDE Visual Alarm State (HIDDEN DRAW)
RCS=127.0.0.1:1026 Source of IP Notify
RCD=2011-04-06 Receive Date of IP Notify
RCT=12:44:58 Receive Time of IP Notify
RCM=GET /control/control?section=exposure&ca_avg_intensity=400 This is the HTTP API message configured in IP Notify
LED=2011-04-08 Last Event Date
LET=18:37:57 Last Event Time
PEV=VM,309.0 Event: Video Motion
PEV=SI2,405.0 Event: Signal Input
PEV=UC,122.0 Event: User Click
PEV=BL,1.0 Event: Button Left
PEV=RC,3.0 Event: IP Receive
PEV=CI,33.0 Event: Serial Interface
ENDSECTION EVENT
hi, please how can i get this metadata from the fastream stream link ( http://<camera_IP>/cgi-bin/faststream.jpg)? I used python request object to make a get request and inspect the returned header, but the metadata was not part of the header content. Please help thank
