Camera API Current time
Hello,
Where can I find the camera current date time on the API?
Thank You
do you need something like https://<cam_ip>/api/json/status/camera/uptime/timestamp ?
@Andrius, do yo know why in some cameras I get this error?
“errors” :
“code” : 2,
“message” : “Error: json_get(): No object or key is not in object.”,
“module” : 3,
“origin” : 1
“code” : 2,
“message” : “repository.json_get(), request_id=43380: core function returnd error.”,
“module” : 4,
“origin” : 1
“code” : 1,
“message” : “HTTPFrontend Error: json_get() failed.”,
“module” : 7,
“origin” : 1
“get” : false,
“status” : 404
Thank You!
It probably is related to FW version the camera is runing.
API/JSON does only exist on models x4 and newer.
The more old fashioned but most compatible API would be
http://CamIP/control/rcontrol?action=gettext&message=$(TMS)
$(TMS) is a system wide Variable.
Anything listed in Camera Online help @ http://CamIP/help/help?longvariable
can be read this way.
Help for “rcontrol”
http://CamIP/control/rcontrol?list
I tried both ways and it works.
Thank You all for the help
:facepunch:.
