MOBOTIX MOVE cameras can be integrated into the MOBOTIX Cloud as well as into a MOBOTIX NVR in parallel. This allows the user to use the MOVE cameras independently in two VMS systems (MOBOTIX CLOUD and MOBOTIX NVR).
MOBOTIX CLOUD:
- Live display
- Recording
- Simple user administration
- Easy access from "everywhere
- Storage in the Cloud
- Backup in the cloud
- Combine multiple locations
- Remote users mainly use the Cloud
MOBOTIX NVR for the cameras at one location:
- Continue to use existing MOBOTIX NVR.
- Local display (e.g. gatekeeper solution → short latency in the live streaming)
- Recording is independent of the cloud
- Remote access can be restricted to admin for maintenance (security aspect)
MOBOTIX MOVE camera the optimal use of streams:
The camera offers three stream profiles. In the hybrid case, the streams are used as follows:
Stream 1:
- Main stream for the Cloud in H264 is preset by the Cloud and can be used in parallel by the NVR as the main stream.
Stream 2:
- Preview Stream in MJPEG for the Cloud is preset by the Cloud.
Stream 3:
- Is not used by the Cloud and can be used by the MOBOTIX NVR . Typically as preview stream in H264 format. (This must be adjusted during commissioning).
Configuration is as follows:
- Connect the cameras to the NVR and select stream 3 of the cameras for the preview.
- Connect the cameras to the cloud (stream 1 and stream 2 are adjusted by the cloud in the cameras).
- Configure stream 3 in the camera accordingly (H264 is necessary and the resolution can be set according to user preferences).
Screenshot for stream settings in the MOBOTIX NVR:
Screenshot for stream settings of the MOBOTIX MOVE camera:
Screenshot of the MOBOTIX NVR after the configuration has been completed:
Attention:
The stream 1 encoder type incorrectly shows H264 instead of MJPEG although MJPEG is set. This is only a display mistake in the NVR.
