MOBOTIX HUB Management Server Failover
MOBOTIX HUB Management Server Failover is designed to ensure that your VMS never skips a beat. It provides MOBOTIX HUB users with an always-hot high availability cluster with real-time replication and failover. It is a complete solution that protects the Management Server (and the Event, Log, and SQL servers when installed on the same physical server) from hardware, software, and human error server failures. Its efficient design and simple configuration, give you the ability to switch to a reliable backup Management Server seamlessly and automatically when the primary one fails. It provides synchronous real-time file replication, automatic application failover, and automatic failback after a server failure, all in one solution.
Each Server License purchased includes a license for both the primary and secondary management server. We only support 1 pair of hosts per site. The host names for servers must be provided at the time of purchase (1).In the case of distributed sites, with separate Management Servers, distinct Server Licenses can be purchased for each site.
MOBOTIX HUB Management Server Failover is compatible with the following MOBOTIX HUB VMS products: MOBOTIX HUB L5 and L4.
Article Code: Mx-HUB-MgmtSrvFailover
Link to our MOBOTIX Store:
Please note: MOBOTIX HUB Management Server Failover is only compatible with versions 2022R1 and higher for the above-mentioned MOBOTIX HUB products.Compatibility with third-party or custom plugins is not guaranteed. Please consult your MOBOTIX sales representative to validate plugin support before purchase or deployment.
