In this article, you will find detailed information on how to configure ports in the Windows Firewall to allow metadata and image traffic on your MOBOTIX SYNC server.
1.- Go to “Control Panel” → “System and Security”
2.- Click on “Windows Defender Firewall.”
3.- Go to “Advanced settings.”
4.- Click on “Inbound Rules” → “New Rule.”
5.- Select “Port” → “Next.”
6.- Select “TCP” → “Specific local ports” → “Next.”
7.- Select “Allow the connection” and click “Next.”
8.- Choose the option that suits your infrastructure scenario and click “Next.”
9.- You can choose the names and description you prefer, then click “Finish.”
10.- In the end, you’ll be able to view the rule created for your MOBOTIX SYNC.
Note: In case you use a port other than the default 8080 to access your MOBOTIX SYNC application, you can make the change in your Firewall at any time.
