Novanetworks InovaPad - Support MOBOTIX Keyboard - EN
Novanetworks InovaPad - Joystick Integration
Joystick (MOBOTIX Keyboard) integration that is plug and play
InovaPad is Novanetworks’ attempt at creating a full joystick integration of the MOBOTIX Keyboard in MOBOTIX HUB VM. With its simplicity of use, this plug-in is aimed at giving its users a better joystick experience. Surveillance operators can switch between cameras and navigate their MOBOTIX HUB Desk Client.
InovaPad is a plugin designed to integrate joystick control into MOBOTIX HUB Desk Client, offering users efficient camera management and enhancing the overall surveillance experience.
InovaPad simplifies the process of camera selection by allowing users to effortlessly navigate through cameras with the preconfigured shortcuts.
The plugin helps managing the content from windows and views, providing operators with a joystick-driven approach to navigate through the Desk Client.
In addition, InovaPad takes advantage of the keyboard characteristics, with the provided jogwheel, to quickly go through recordings. This jogwheel integration lets the user efficiently investigate through camera recordings.
Key features
  • InovaPad works with the following supported devices: MOBOTIX Keyboard; DCZ Videotec Keyboard;
  • Operators can navigate Views with ease.
  • Efficiently go through recordings.
  • Send cameras to Video Walls.
How it works:
InovaPad allows operators use the Desk Cleint with only the MOBOTIX Keyboard, while controlling multiple monitors.
InovaPad buttons can be configured in the settings
Configure which type of keyboards operators will be using
How to install
InovaPad User Guide
  • Contact: contact@novanetworks.tech
The Plug In has already been successfully used by the MOBOTIX project team in France and has been tested with the following MOBOTIX HUB versions:
  • MOBOTIX HUB 2021R2 and 2022R1
  • Versions HUB L2 to HUB L5
