Xprotect LPR Add On - Install Guide (ENG)
MOBOTIX HUB XProtect LPR allows you to read license plate information from vehicles and combine it with corresponding video. It is designed to fit MOBOTIX HUB products perfectly, and it integrates seamlessly with MOBOTIX HUB Desk Client. With optimized recognition algorithms for more than 200 countries and states around the world and advanced matching logic, you can compare recognized number plates with pre-defined lists and initiate automated actions. Gain efficiency and increase productivity with a wide set of application areas, including access control, theft prevention, and border control.
Install MOBOTIX HUB XProtect LPR
The necessary installation files (details are set out in the manual):
These can be downloaded from our Software Download in the MOBOTIX HUB section:
Please refer to the Manual Guide of the Management Client (Please check the latest Version of Manual for changes). But in General the Installation is as decribed in 2022 R1 Manual:
The Landingpage MOBOTIX HUB Ad on´s contains more infos about all available Add on´s:
A good overview document with useful infos for the LPR Add on is:
