Introduction
An application-programming interface (API) is a set of programming instructions and standards for accessing a software application or Web tool. An API is a software-to-software interface, not a user interface. With APIs, applications talk to each other without any user knowledge or intervention.
MOBOTIX HTTP API
The HTTP API (Application Programming Interface) is a software interface to the camera and allows to conveniently integrate the camera into a centralized management system. The interface consists of several CGI scripts that can be called with parameters and values using HTTP commands. By means of these scripts, you can modify the settings of the dialogs in Setup Menu and execute certain camera functions.
Most common uses
- Modification of the configuration: recordings, events, actions, etc.
- Modification of the image settings: exposure, image quality, image resolution, etc.
- Status requests
- Triggering of actions
API HTTP request description
A normal HTTP request from the browser looks like this:
http://<ip_address_for_the_camera>/control/control?list§ion=recording
which can be split in the following:
- protocol: http://
- destination: <ip_address_for_the_camera>
- cgi-call: /control/control
- parameters: list§ion=recording
so a well formed request is of the form:
protocol + destination + cgi-call + parameters
The previous request will deliver the following HTTP response:
where the current configuration options for recordings are visualized.
CGI Calls
/control/control
Using the HTTP command
you can modify the settings of the Setup menu. Type
to display the different sections available.
/admin/control
http://<ip_address_for_the_camera>/admin/control
you can modify the settings of the Admin menu. Type
http://<ip_address_for_the_camera>/admin/control?list
/control/rcontrol and /admin/rcontrol
http://<ip_address_for_the_camera>/control/rcontrol?list
you can visualize specific actions which can be executed
http://<ip_address_for_the_camera>/control/rcontrol?action=sound&soundfile=Alarm
by calling this HTTP request the camera will play a sound file.
Some of these functions can only be called as an admin user
in this case the HTTP Request would be:
http://<ip_address_for_the_camera>/admin/rcontrol?action=reboot
vPTZ Settings
As a consequence of integrating the Q camera models, the cameras offer vPTZ features (virtual Pan/Tilt/Zoom) also in the HTTP API. The corresponding features have been documented on specific help dialogs, which can be opened using the corresponding links:
click.cgi
This interface provides limited access to simple vPTZ features.
http://<ip_address_for_the_camera>/control/click.cgi?help
rotor.cgi
This interface provides full access to all vPTZ features.
http://<ip_address_for_the_camera>/control/rotorcgi?help
control?list§ion=vptzcontrol
control also provides access to some vPTZ features, as outlined in the vptzcontrol section.
http://<ip_address_for_the_camera>/control/control?list§ion=vptzcontrol
Image CGI-Calls
Additionally there is a set of CGI calls to retrieve live images, video streams and recordings of the camera directly from the integrated web server.
/record/current.jpg
http://<ip_address_for_the_camera>/record/current.jpg
- Retrieves a camera image according to the current image settings
- You cannot specify any additional parameters
/cgi-bin/image.jpg
http://<ip_address_for_the_camera>/cgi-bin/image.jpg
- Retrieves a camera image using additional image parameters.
- The saved configuration is not changed and does not affect the live image.
http://<ip_address_for_the_camera>/cgi-bin/image.jpg?camera=right&size=320x240&quality=60
- camera=right is the right lens on dual cameras
- size=320x240 is the resolution of the image
- quality=60 is the quality percentage
Appending ?help to the end of the command will display the corresponding help page with all the options available:
http://<ip_address_for_the_camera>/cgi-bin/image.jpg?help
/cgi-bin/faststream.jpg or /control/faststream.jpg
Retrieves the live stream from the camera using additional image parameters.
- /cgi-bin/faststream.jpg with guest access
- /control/faststream.jpg with user access
/control/event.jpg
Provides access the camera’s events and allows adding additional parameters.
http://<ip_address_for_the_camera>/cgi-bin/event.jpg
The following request, for example, delivers the last event image of the camera:
http://<ip_address_for_the_camera>/control/event.jpg?sequence=head
Appending ?help to the end of the command will display the corresponding help page with al the options available:
http://<ip_address_for_the_camera>/control/event.jpg?help
Additional help
The help pages on the camera provide an overview of the API commands and addtional examples. The help pages can be accessed clicking on the ? icon on the top right corner of the camera web interface or via the url:
http://<ip_address_for_the_camera>/help/help
Down at the bottom of the MOBOTIX Online Help is the Remote-Controlling section
