I am having problems with the “https://” links from the logos menu, it only works with “http://" and this is a problem with the security policies of all the web pages.
Any solution?
Any solution?
Unfortunately images loaded from URL do not support HTTPS. As the error message indicates only HTTP is supported. In this case the camera is a client retrieving an image so it does not compromise the security of the camera itself.
Since the camera is not supporting this, you might use an external web server which downloads the image and converts it from HTTPS to HTTP.
We have forwarded your request to our Product Management for their consideration.
