Dallmeier Panomera integration in MOBOTIX HUB - EN
See more with less - MOBOTIX HUB and Panomera®
Unlimited “Virtual PTZs” lets MOBOTIX HUB users gain maximum control of large spaces and long distance
With Panomera®, MOBOTIX HUB users can survey huge areas and/or long distances in exceptional detail with significantly fewer cameras than with conventional solutions. Just like one big image created from multiple megapixel cameras combined with an unlimited number of “virtual PTZs”.
Overview
See more with less - MOBOTIX HUB and Panomera® - Unlimited “Virtual PTZs” lets MOBOTIX HUB users gain maximum control of large spaces and long distance
In contrast to single-sensor cameras, the MFS technology works with several sensors (“multisensor”), each operating with different focal lengths (“multifocal”).
Thus, Panomera® cameras with “Multifocal Sensor Technology” also capture rear and middle image areas with the same high resolution as scenes in the foreground. With unique advantages in video surveillance, video monitoring and video analysis.
That way, large areas or long distances can be surveyed in exceptional detail with very few Panomera® systems. In addition to a vastly improved overview and better control of any large spatial context, Panomera® helps customers to significantly reduce infrastructure and operating cost.
Key features
  • Significantly fewer cameras and screens
  • Several times greater area coverage with same personnel
  • Reduced workload for operators
  • More granular, higher dynamic range
  • Nothing gets lost: Unlimited „Virtual PTZs“, live and recorded
  • MOBOTIX HUB VMS
  • Panomera® S Series Multifocal Sensor Camera
    Supported Models:
    • Panomera S8 190/30
    • Panomera S8 184/45
    • Panomera S8 78/75
    • Panomera S8 66/13
    • Panomera S8 87/45 DN
    • Panomera S8 43/90 DN
    • Panomera S4 46/15 DN
    • Panomera S4 46/30 DN
How it works:
MOBOTIX HUB operators can open and organize all Panomera “submodules” from the MOBOTIX HUB Desk Client user interface, drag and drop, zoom into any number of areas within the submodules simultaneously.
Panomera combines up to 8 lenses & sensors in one optical system.
The result is up to 190 Megapixel “effective resolution” and equal image quality across the entire scene.
Theoretically unlimited “virtuals PTZs” at the click of a mouse.
All manageable through MOBOTIX HUB.
How to install:
License Activation:
This solution does have a build-in MIP license check that is locked to the software license code (SLC) of
the MOBOTIX HUB installation of which it is a part.
It automatically comes with a 30 days grace period which starts from the date when the plug-in is installed.
After the grace period expires, a permanent MIP license is needed.
The permanent MIP licenses are provided via MOBOTIX . In order to generate a permanent MIP license, please provide the Software License Code (SLC) of the MOBOTIX HUB system where the Panomera Plugin has been installed. Collect the SLC and send it to the sales@mobotix.com.
When the permanent MIP license is acquired, the MOBOTIX HUB system must be reactivated, either online or offline.
If MIP license check fails, the plug-in will issue error messages and will have a reduced functionality.
Installers
Here you can find more information about installers and installation guides
Panomera_S-Series_V1-MX.pdf (2.0 MB)
