Hallo Mobotix community,
Do you know if there is a way to use HTTP API to temporary enable HTTP?
Reason is that I need to push the config to multiple camera’s and it only works with HTTP ON. I activate it manually and after the push disable it again.
Something like this:
/admin/control?set§ion=webserver&http=enable
Thank you ![]()
