This is the procedure to display camera pop-ups on a MxThinClient.
Please Note: The MOBOTIX IoT and MOVE cameras will need to be added to the MxThinClient before hand.
- Setup MxMessageSystem on the MxThinClient
Network settings: MxMessageSystem – Distribution of Message over the Network > Enable Networking
Important: Make sure that these entries are identical to the entries in the MxMessageSystem configuration of all cameras or door stations that are sending messages.
- Setup MxMessageSystem on the required camera
a. Admin Menu > Network Distribution of Messages > Enable Networking
b. Admin Menu > Message Profiles for Actions Groups > Create a new profile
Create a MxMessageSystem Name (this will need to be identical throughout the rest of the process.)
Ensure you select “Global” on the Message Range
- Setup the Event to trigger the MxMessage
Setup Menu > Event Overview
Most common triggers are VM, AS, Signal Input, UC Event
AS will be used in this example
- Create an Action Group
Setup Menu > Action Group Overview
Event Selection= Desired event in Step 3
Action will be the MxMessage
- Configure the MxThinClient to listen for this message
MxThinClient > Image Sources > Required Camera > Message Name
Ensure you add the MxMessageSystem Name created in Step 2b. (Remember it must be identical)
Please Note:
All cameras and MxThinClients will need to be time synchronized
The popup camera will only pop-up for the defined sequencing duration time.
