Each AI app selbs can provide its own MJPEG stream.
the URL for this is as follows:
https://ip-adresse-p7-camera:AppPort/local/Appname/frame.cgi
example Livestream AI traffic:
https://192.168.1.252:28621/local/AITraffic/frame.cgi
How to get this stream into the MxHub can be seen in this article
1. Activate and configure your AI-App
2. Add the AI-Tech Livestream into the MxHub
→ ManagementClient → Recording Server → Right Click → Add Hardware
Select Manual
Click Next
Add your camera credentials of your camera admin user
Click Next
Select as Driver Universal → Universal 1 channel driver
Click Next
Fill in the IP-Adresse of your camera on which the AI-App is running
Select Universal 1 channel driver as Hardware Model
Click Next
Hardware will be detected:
Click Next
Hardware informationen will be collected
Click Next
Click Next
Select your default camera group
Click Finish
3. Configure the Universal Camera
→ ManagementClient → Recording Server → Select the Universal 1 channel driver
Click on Settings
Set the following Settings:
HTTPS Enabled: Yes
HTTPS Port: "Port of the AI-App Webserver"
HTTPS Validate Certificate: No
HTTPS Validate hostname: No
Include URI Ptions on RTSP PLAY request: No
Click on the universal 1 channel driver camera in the Recording Server tree
Set the following settings:
No you should be able to see the livestream of your AI-App
It is only possible to receive a resolution of: 640x360!!
4. Configure AI-App for MxHub Recording
Open your AI-App → Configuration → Event → Milestone Event
Set up the Server IP of your MxHub Server
Set up the Server port: "Default: 9090"
Set up the Device IP which the Event is related to
Select the AI-App Events which should trigger this event
Enable the Analytics Events in the MxHub
→ ManagementClient → Tools → Options → Analytic Event
Create a new Analytic Event.
The name for this event is Road (AITraffic App)
Analytic Event name for AI-Apps:
AITraffic: Road
AIBiodeep: Bio
AICrowdDeep: Overcrowd
AIFacedetect: Face
AIFire: Fire
AIIntrusionPro: Sterile_Zone, Crossing_Line, Intrusion_Pro
AILoitering: Loitering
AILost: Lost
AIParking: Parking_Spot_Change, Parking_Lot
Create a Rule for Recording
Now your system will receive a livestream directly from the AI-App and will record, when an event is triggered by the app
Short clip of how a recording looks like
