Move a MOBOTIX HUB Recording Server to another Server Hardware
- Install the Recording Server on the target server. The Recording Server service will start automatically when the installation is complete.
 - Stop the Recording Server service on both the source and target servers.
 - Copy the file RecorderConfig.xml from the source server to the same folder on the target server (typically found in C:\ProgramData\Milestone\MOBOTIX HUB Coporate Recording Server\
 - Start the Recording Server service on the target server. It will assume the identity of the old server and download its configuration from the MOBOTIX HUB Management Server.
Note:
- For best results, the storage configuration and drive letters should be identical on the old and new servers.
 - Never run the Recording Server service on the old and new systems simultaneously.
