Hi,
Our camera:
Camera Identifier
Product Type: MOBOTIX v26B-6D
Serial Number: 10.26.54.132
Ethernet Hardware Address: 00:03:C5:1A:36:84
Factory IP Address: 10.26.54.132
Camera Code: 1A3684
Hardware
Board Revision: 6.4
Processor Type: ARMv7 Processor
Bootloader: 8.0.0.0
Operating System
Type: Linux
Release: 4.6.0-rc5+
Release Date: #1 SMP Thu Feb 15 16:55:40 CET 2024
File System
Release: MX-V5.4.9.9-r1
Creation Date: 2024-10-22 09:49:44 UTC
Initial Size: 77564 KB
ActiveX Version: 1.8.8.0
( I believe firmware is the latest one? )
In General Image Settings I have set to 6MP option, but via first ONVIF Media Profile /stream/onvif-default0 I get only some strange resolution 1280x848. Also, ONVIF declares it’s 30fps, but in reality I barely get 3fps (output from gst-launch-1.0) via RTSP stream:
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 8, dropped: 0, current: 2.40, average: 2.47
I did tried to go to Integration Protocols and reset Onvif to factory, and Reset profiles, but nothing helps.
One time I (somehow) managed to get 1920x1080 via Onvif, but it still failed to reached declared 30fps (not sure why it declares 30fps via ONVIF media profile, as it was set to 20 or 25 max). It was running barely on ~14fps.
I really need that 6MP with at least 15-20FPS via ONVIF default first profile. Is that doable?
Thanks!
