Installing MxMC on Linux with Wine
Wine is neither an emulator nor a virtualisation solution. The project has set itself the task of recreating the Windows environment, including all the necessary libraries for Windows software. It allows the MOBOTIX MxMC to be installed on a Linux environment. These instructions show this step by step.
Disclaimer
MOBOTIX AG officially offers MxMC only for the Windows and Mac operating systems. The use with Wine is an alternative for all users who are familiar with Linux and the limitations of Wine. Support requests can therefore not be handled by MOBOTIX AG.
In the MOBOTIX community, however, this is a welcome contribution that will find its supporters!
What is required:
- MxManagementCenter 2.9.1 (or newer): https://www.mobotix.com/en/node/20442
- Linux Mint 22 Wilma (operating system based on Ubuntu) Download: https://linuxmint.com/
- Etcher (to create a bootable USB stick, not required if you are running a virtual machine like VM Ware) Download: https://etcher.balena.io/
Step-by-step instructions
- Download Linux Mint 22.
Linux Mint comes in the form of an ISO image (an .iso file) that can be used to create a bootable DVD or a bootable USB stick. - Download Etcher or similar software to create a bootable USB stick.
- Follow the Etcher installation and configuration instructions
- Insert the stick into your PC or start the ISO image if you are using a virtual machine.
Choose your language
Select keyboard
Install multimedia codecs
Erase hard drive and install Linux Mint
Once the installation is complete, start the terminal and enter :
Linux Commando:
sudo apt-get update
After that
Linux Commando:
sudo apt-get upgrade
Install Wine by entering
Linux Commando:
sudo apt install wine
Once it is installed, open the configuration panel for wine.
Linux Commando:
winecfg
Go to Libraries and add the following options
Now download the MxManagementCenter installation file or copy it to the ‘Downloads’ folder.
Open the terminal and navigate to the download folder as shown in the screenshot
Start the installation as shown in the screenshot
The installation process begins
Nach der Installation starten Sie das System neu und starten das MxManagementCenter
Installation ist nun abgeschlossen!
Video:
How to Install PDF:
2025-01-02_MxMC Linux Installation.pdf (1.6 MB)
