MOBOTIX partner SEDi (info@sedi-deutschland.de , http://sedi-deutschland.de/) produces and distributes a hardware P/T unit with PelcoD protocol fully integrated into ManagementCenter version 2.1.1 or later, the “PT5”.
Find the installation manual here:
Manual PT5 english PoE V1.7 D-S.pdf (3.7 MB)
The pin layout on the unit needs to be adapted to the use case:
MxCC
„PT4-Setting“
Supported Cameras: All MXCameras
with USB (every Firmware)
MxMC
(Version 2.1.1 and above)
(and MxCC (Pelco-D Setting))
Supported Cameras: Mx6
(Firmware V5.2.4.15 and higher)
Mx5 (Firmware V4.7.2.34 and higher
This is how to setup ManagementCenter to use the PT5:
Open the camera Configuration in MC
Change „Connection Protocol“ from „MOBOTIX“ to „MOBOTIX with PelcoD“
Restart MxManagmentCenter
Click and hold the left mouse-button for at least 3 seconds on the „Plus-Symbol“
A crosshair will appear in the upper left corner.
You are now able to control the PT-Unit with your mouse, while holding the left mouse-button inside the picture and moving it to any direction. By clicking on the „Position-Symbol“
next to the „Plus-Symbol“ you can also call Preset-Positions.
Download as pdf:
PT5-MxMC Configuration_1.pdf (1.6 MB)
Data sheet:
SEDI PT5 Data sheet - 18-19.pdf (637.5 KB)
Declaration of Conformity:
Declaration of Conformity PT5.pdf (573.0 KB)
