MOBOTIX HUB Fisheye PlugIn for Milestone XProtect
Correction of a fisheye image in the live and playback view
Fisheye correction allows the Smart Client user to rectify any camera with a fisheye lens according to requirements. This is done by activating the function in the camera channel via a slider. This can be used to define the degree of equalisation.
This function can be applied to the saved video data in the live image and in the playback view.
The user can switch between the corrected and original image at any time. The camera image is recorded unchanged and is based on the original format.
The function is hidden under the following symbol: ![]()
The corrected (rectified) image:
The user can use the digital zoom function of the Milestone XProtect to move back and forth in the corrected image. The rectification is also taken into account in Zoom mode.
Correction of the image in the playback view:
Further image optimisation effects that can be applied to the image
These effects are based on different calculation algorithms with additional setting options than the ‘Fisheye’ option. Depending on the camera, lens type or camera position, these effects may be more optimal than the first option ‘Fisheye Correction’.
Milestone XProtect Smart Client Player - supports the Fisheye plugin
The Smart Client offers the possibility to export video data including a stand-alone player application (Milestone XProtect Smart Client Player). This allows third parties such as the police, public prosecutor’s office or insurance companies to conveniently play back the transmitted video material with the Milestone XProtect Smart Client Player. The Fisheye PlugIn supports this separate Smart Client Player and the user can equalise the fish-eye image as in the Milestone XProtect VMS!
ManagementClient setting options
In the Management Client, the admin can specify whether use is unrestricted or whether only certain users can use the Fisheye function.
In the factory setting, access is blocked for all users. (Remove the ‘Restrict Access’ tick)
Requirements:
- Milestone XProtect Version 2024 R2 or newer
- Milestone XProtect Hotfix Video Effect or newer
- MOBOTIX HUB Plug-In´s 2025-03-27 or newer
The required Fisheye PlugIn licence from MOBOTIX- Mx-SW-XPro-FishE-Base for 8 cameras
- Mx-SW-XPro-FishE-Dev extend support to +16 cameras
Important: Licenses do NOT support virtual machine environments.
For custom development options, please contact our Product Management team via Sales: sales@mobotix.com to request a quote.
Demo/trial version available:
MOBOTIX Order Code: Mx-SW-XPro-FishE-Base-30
Enquiries Please contact order@mobotix.com
