MOBOTIX HUB Cloud Plugin – Everything at a Glance, One System
With the MOBOTIX HUB Cloud Plugin, integrating modern VSaaS cloud video solutions into existing on-premises environments is easier than ever before.
Traditional VMS systems like the MOBOTIX HUB have traditionally been strong in the area of local installations. At the same time, there is a growing need to seamlessly integrate cloud-based cameras and locations (VSaaS) as well. This is exactly where the Cloud Plugin steps in.
One System – Regardless of the Technology
The central goal is quite clear:
Users have access to a single system where they can view all relevant cameras—regardless of the technology used.
With the plugin:
- Cloud cameras are integrated directly into the MOBOTIX HUB VMS
- Remote locations operated via Cloud VMS are made visible
- Live views and playback are supported
Cloud-Ready – More Flexibility
The plugin enhances the classic HUB system with true openness:
- Integration of MOBOTIX CLOUD
- Integration of Eagle Eye Networks Cloud
- Support for multiple cloud subaccounts
- Flexible selection of cameras to be displayed in the HUB
Centralized Management Without Restrictions
A key advantage:
Integration takes place without interfering with existing cloud usage.
This means:
- Cloud systems remain self-sufficient and independent
- Other users can continue to work via the cloud as usual
- No restrictions on existing workflows
The HUB thus becomes the central display and control interface, without the need to alter existing structures.
Free and easy to integrate
The MOBOTIX HUB Cloud Plugin is:
available for free
quick to integrate
ideal for hybrid video architectures
Conclusion
With the MOBOTIX HUB Cloud Plugin, everything that belongs together comes together:
On-premises and cloud in a single system.
For users, this means:
- Greater clarity
- Fewer system changes
- Maximum flexibility
*** Translated with www.DeepL.com/Translator (free version) ***
Management Client – Setting Up the Cloud
IMPORTANT:
There are two types of accounts in the cloud:
- Reseller Account
- Sub Account
Only the Sub Account contains cameras and must be configured in the Management Client!
You can add as many sub accounts as you like, e.g.:
- MOBOTIX CLOUD
- MOBOTIX CLOUD 2
- MOBOTIX CLOUD 3
- Eagle Eye Networks CLOUD
Desk Client – Adding Cloud Cameras
In the MOBOTIX HUB Desk Client, cameras are selected as following:
- Select the desired Cloud Sub Account
(e.g., “Demo 1,” as configured in the Management Client) - The available cameras for the sub account appear in the next dropdown menu:
Note:
The dropdown menu may be empty if no cameras have been created in the cloud account yet.
These must first be added to the cloud.
For example, if no cameras have been added to the subaccount yet:
Video: Integrating and Using the Cloud in the HUB
Example using a MOBOTIX CLOUD account (same for Eagle Eye Cloud):
