MOBOTIX HUB 1000 Cameras (FullHD, 25FPS, 30 Days Storage)
Project Requirements:
| Codec | H.264 |
| FPS | 25 |
| Days of storage | 30 |
Recording Server Specification (2x Recording Servers needed)
The following information refers to one recording server. Depending on the size of the installation, several servers may be required to record the data from the cameras.
| CPU | Xeon Silver 4208 @ 2.10GHz |
| RAM | 16 GB RAM |
| OS | Windows Server 2019 Standard (or other support OS) |
| Live Database Disk Configuration: | 12 x Enterprise 1 TB RAID 1 RAID 10 |
| Archive Database Disk Configuration: | 12 x Enterprise 18 TB RAID 5 |
| Estimated IOPS: | 1323.30 |
| Rec. Server Video Storage: | 179.83 TB |
| Network Interface Controller: Cameras | 555.03 Mbps |
| Network Interface Controller: Client (1000 Cams Live) | 2.78 Gbps |
| CPU | Intel Xeon Silver 4208 |
| RAM | 12 GB RAM |
| OS | Windows Server 2019 Standard ( or other supported OS) |
| Size OS / Application | 300GB |
| HDD Type: | 2x Enterprise |
| RAID | RAID 1 |
| SQL DB and Transaction Logs / Application | 300GB |
| HDD Type: | 4x Enterprise |
| RAID | RAID 10 |
MOBOTIX HUB 1000 Cameras (4K, 25FPS, 30 Days Storage)
| Codec | H.264 |
| FPS | 25 |
Recording Server Specification (20x Recording Servers needed)
| RAM | 16 GB RAM |
| Live Database Disk Configuration: | 12 x Enterprise 1 TB RAID 1 / RAID10 |
| Network Interface Controller: Client (1000 Cams Live) | 11.10 Gbps |
| RAM | 12 GB RAM |
| OS | Windows Server 2019 Standard( or other supported OS) |
| RAID | RAID 1 |
| RAID | RAID 10 |
