MOBOTIX HUB 50 Cameras (FullHD, 25FPS, 30 Days Storage)
Project Requirements:
| Codec | H.264 |
| FPS | 25 |
| Days of storage | 30 |
Recording Server Specification
The following information refers to one recording server. Depending on the size of the installation, several servers may be required to record the data from the cameras.
| CPU | Xeon Bronze 3204 @ 1.90GHz |
| RAM | 16 GB RAM |
| OS | Windows Server 2019 Standard (or other support OS) |
| Live Database Disk Configuration: | 4 x Enterprise 1 TB RAID 1 RAID 10 |
| Archive Database Disk Configuration: | 4 x Enterprise 18 TB RAID 5 |
| Estimated IOPS: | 330.82 |
| Rec. Server Video Storage: | 44.96 TB |
| Network Interface Controller: Cameras | 138.76 Mbps |
| Network Interface Controller: Client (50 Cams Live) | 138.76 Mbps |
| CPU | Intel Xeon Bronze 3204 |
| RAM | 12 GB RAM |
| OS | Windows Server 2019 Standard( or other supported OS) |
| HDD Type: | 2x Enterprise |
| RAID | RAID 1 |
MOBOTIX HUB 50 Cameras (4K, 25FPS, 30 Days Storage)
| Codec | H.264 |
| FPS | 25 |
| CPU | Xeon Silver 4208 @ 2.10GHz |
| RAM | 16 GB RAM |
| Live Database Disk Configuration: | 12 x Enterprise 1 TB RAID 1 / RAID10 |
| Archive Database Disk Configuration: | 12 x Enterprise 18 TB RAID 5 |
| Estimated IOPS: | 1323.30 |
| Rec. Server Video Storage: | 179.83 TB |
| Network Interface Controller: Cameras | 555.03 Mbps |
| Network Interface Controller: Client (50 Cams Live) | 555.03 Mbps |
| RAM | 12 GB RAM |
| OS | Windows Server 2019 Standard (or other supported OS) |
| RAID | RAID 1 |
