I have installed an MX display for a customer in the UK, unbelievably I cannot be set to UK time. Has anybody got a work around? Do I have to tell the client that Mobotix cannot display the time correct in the UK.
hello @rjb0104 ,
this should work with the following setting:
Settings → Installation → MxDisplay Configuration → Date & Time → Time Zone → Europe → London (Europe/London).
Select this and don’t click on the home button, click step by step back to the home screen
Thank you for the prompt reply.
I think the real problem is when we change from BST to GMT and you then need to reset it again.
If you know better I would be very grateful for a solution.
