Is it possible to add a softbuton to the app in order to turn on a Light or another device? I have several clients that have integrated different options by pressing the light button that the previous version had.
Some alternative?
Hi,
the actual version of MxBell implements only the door opener soft button. More buttons will be added in the next versions.
If you are using iOS device and need multi-buttons you can use MxApp (but without push notifications) otherwise 3rd party application which are completely compliant to MOBOTIX devices such as QCam Pro.
Hope it helps
Best regards
Pierpaolo Amadori
BDM Italy & Malta
Hi Devision
you can check this link maybe can help you, let me know: https://community.mobotix.com/t/how-to-open-the-door-and-at-the-same-time-turn-on-a-light-on-mxbell-using-mx232-io-box/174
