The $(EVT.EST.ACTIVATED) in IPNotify for Push-Notification property contains ALL the events that were activated at that time point. Someone if the configuration activates additional events and so the user sees multiple ones, which is not wrong.
Example: Push Notification is configured when ActivitySensor (AS) detects a movement. In some cases the Push-Notification shows also other events in the push-notification and not only AS.
Currently, the camera always delivers all the events, and not the actual one (AS in this case). Suggested solution would be to replace the IPNotify profile message with " ALARM from (ID.NAM) at (TMS.HOUR):(TMS.MIN) on (TMS.MON)/$(TMS.DAY) " instead of using the property.
