Record storage issue
hello please i need help.
after I connect my my camera to the storage, it gives me this error.
please see the result of my camera
“Test result:
The file server is usable, but required available space could not be verified! Please manually check the file server!”
I have enough space what should I do now?
Hello @msharara ,
If you are sure that you have enough disk space on your file server, you can ignore this message.
The file server test checks with which transfer protocol versions a connection can be established and in your case returns the message that the file server can be used in principle.
It also checks whether there is enough disk space available so that the upper limit you have specified is not exceeded. A warning is issued here if this is not the case, e.g. if no limit has been specified.
It is therefore best to check whether the limit you have specified is correct.
In the log window of the file server test (you may have to allow pop-ups) you can see more details about what exactly is being tested.
please see error 75 and the diagnostics.
Note: There is no output in the main window while the test is running!
Starting File Server Test.
Trying to mount “/MOBOTIX_US” on “10.1.10.31” using “NFS”.
OK
Trying to create directory “00_03_C5_20_90_67_1742480431”.
OK
Trying to create file “00_03_C5_20_90_67_1742480431/testfile”.
OK
Trying to write to file “00_03_C5_20_90_67_1742480431/testfile”.
OK
Trying to open file “00_03_C5_20_90_67_1742480431/testfile” for reading.
OK
Trying to read from file “00_03_C5_20_90_67_1742480431/testfile”.
OK
Trying to remove file “00_03_C5_20_90_67_1742480431/testfile”.
OK
Trying to remove directory “00_03_C5_20_90_67_1742480431”.
OK
Trying to get file server statistics from [/tmp/mounttest/10_32_144_103] on “10.1.10.31/MOBOTIX_US”.
Failed
Error: 75
Statistics
Server capacity: 0.00 GByte
Currently available space on file server: 0.00 GByte
OK
Trying to read settings for ‘Storage Size’.
Settings
Storage Size: UNLIMITED
Target Type: nfs
OK
Checking if storage will fit on file server “10.1.10.31/MOBOTIX_US/10_32_144_103”.
Statistics
OK
Trying to unmount “/MOBOTIX_US” on “10.1.10.31”.
OK
Test result:
Hello everyone,
We have fixed it by creating a Linux server and then letting the camera store on it.
