Please help me, I’ve done a way to activate smb from GPO in windows, but when cctv tests, there’s always the following display, while storage on the disk is secure, the connection is stable.
Fileserver Test Log
Note: There is no output in the main window while the test is running!
Starting File Server Test.Checking for usable CIFS versions:
“timestamp”:“2024-01-24T08:17:19+0700”,
“Versions_tested”:[
“SMB”:“2.0”,
“auth”:“ntlmssp”,
“result”:“ok”
“SMB”:“3.02”,
“auth”:“ntlmssp”,
“result”:“ok”
“SMB”:“3.0”,
“auth”:“ntlmssp”,
“result”:“ok”
“SMB”:“2.1”,
“auth”:“ntlmssp”,
“result”:“ok”
“SMB”:“1.0”,
“auth”:“ntlmssp”,
“result”:“ok”
“SMB”:“1.0”,
“auth”:“ntlm”,
“result”:“ok”
}Trying to mount “MobotixE” on “192.168.4.250” using “CIFS” as user “admincctv”.
OKTrying to create directory “00_03_C5_1C_68_2B_1706059039”.
Failed
Error: 13Test result:
The file server is NOT usable!
