Redundancy Management Framework (RMF) from VEGA
High Availability Situational Awareness at Redundant MOBOTIX HUB Deployments.
Our software provides an easy path towards achieving full MOBOTIX HUB Redundancy. Cause agnostic failure detection, instantaneous video recovery, and redundancy management all come together in a software package that integrates into MOBOTIX HUB to provide a single pane of glass experience.
Redundancy Management Framework (RMF) - High Availability Situational Awareness at Redundant MOBOTIX HUB Deployments.
Our MOBOTIX HUB plugin, the Redundancy Management Framework (RMF), offers valuable support to facilities transitioning from non-redundant video security architectures to redundant ones, promoting high-availability situational awareness by leveraging redundant data centers.
Integrated with each Desk client view, independent, cause-agnostic failure detectors identify failures in a user-aligned manner, facilitating fast failure mitigation through democratic decision-making.
Our powerful tools also enable seamless camera data synchronization and role-based access across redundant data centers, simplifying site management.
Furthermore, support for federation allows for the logical separation of redundant infrastructures, streamlining software update workflows without compromising situational awareness.
The RMF has successfully aided critical infrastructure facilities worldwide in building and leveraging redundancy to enhance their security systems.
Key features
- Cause Agnostic failure detection integrated into each Desk Client view is aligned with user perception of failure.
- Live video recovery is Lightning fast and automatic. Playback is continuous, and switching between redundant sources is transparent to the end user.
- Support for asymmetric redundancy makes redundancy flexible and caters to a diversity of budgets.
- Compatibility with unique redundancy architectures streamlines software updates and eases IT management tasks.
- Redundant event pipelines deliver high-availability alarms.
- VEGA Redundancy Management Framework
- MOBOTIX HUB VMS
How it works:
The Redunancy Management Framework helps Critical Infra facilities achieve High Availability Situational Awareness through many types of outages:
Discover the top differentiators of the Redundancy Management Framework solution:
Effortlessly update passwords across multiple cameras an data centers in a redundant architecture. Update passwords frequently and uphold high-security standards:
Hybrid Redundancy, enabled by RMF. RMF provides a path for traditional large, on-prem deployments to leverage the power of the cloud while increasing system availability:
Nuanced and video-aware, RMF handles failures, big and small:
RMF 5.0 adds support for asymmetric redunancy at MOBOTIX HUB deployments. Asymmetry makes possible a range of redundant system designs at different cost points:
Here is a demo of RMF 5.0. A key feature is support for Asymmetric Redundancy. Aysmmetry enables unequal numbers of primary and redundant servers. This enables a range of cost-performance tradeoffs:
A demonstration of RMF 5.0 set up in federated mode:
RMF’s REST API enables third party components at the site to leverage redundant recording:
Screenshot depicting automatic streaming from the redundant recording server to the MOBOTIX HUB Desk client upon failure of the primacy server:
With RMF, the complete failure of storage and recorder does not impact the users ability to retrieve archived video content:
RMF 4.0 and 5.0 make it easy to configure alarms for redundant recording:
RMF’s REST API enables PSIM, Analytics, and access control providers to lerverage recording redundancy:
A demo of RMF installation:
Our new Outage and Mitigation Simulator for MOBOTIX HUB deployments is an interactive online simulation tool for MOBOTIX HUB infrastructure architects:
How it works:
need_for_dr.pdf (292,6 KB)
overview_23.pdf (1,1 MB)
rmf-a-e-specs.pdf (574,5 KB)
rmf-white-paper.pdf (1,9 MB)
rmf_data_sheet.pdf (1,3 MB)
