S74 and External SSD issue
Hello,
We have S74 units and are trying to add external storage to the units using Samsung Shield T7 4TB SSD. In the hardware expansion slots, I have tried enabling both USB SSD / Flash Device or USB External Harddisk but when i try to format the drive it states it cannot detect a drive to format and to enable it in the hardware expansion slot.
The drive shows it is getting power from the USB port of the S74 but i cannot format it. Are these not compatible with the S74?
An update:
So, the camera sees the drive if i do set the storage point to Flashed SSD but does say it isn’t formatted. Shows 4TB, etc. But still will not format the drive as it states “to enable it in hardware configuration” which it is.
I have tried formatting the drive to ext4 and FAT32 as well to see if i could then format it via the camera but still no luck.
