HD Over COAX
HD Cameras communicating over coaxial cable is a growing portion of the video marketplace and MOBOTIX CLOUD integrates with multiple technology partners to deliver support of these types of cameras. The use of HD Over Coax cameras requires a recorder or encoder which is compatible with the specific cameras (TVI, SVI, CVI, or other HD Over Coax technology), and is supported by MOBOTIX CLOUD. Supported recorder or encoder devices will be connected to the MOBOTIX CLOUD Bridge via the CamLAN port and the bridge will receive two streams per camera from the device.
Compatible recorders and encoders will:
- Work with any MOBOTIX CLOUD Bridge
- Are Cyber Secure when using MOBOTIX CLOUD CamLAN
- Will allow resolution to be selected on a “per camera” basis
- Will allow retention to be selected on a “per camera” basis
In addition to the benefits of the MOBOTIX CLOUD , HD Over Coax has specific advantages over standard analog or IP based systems:
- 4x longer cable runs compared to Ethernet
- The cost of cameras is generally lower than IP cameras
- Plug and Play camera installation
- Secure and stable environment (No I.P.s, Latency, QoS or Network Issues)
- 2MP cameras offer five to six times more resolution than analog CCTV cameras
Analog
MOBOTIX AG offers on Project request analog-ready Bridges from our technology partner. The analog-ready bridges will digitize the video coming from analog cameras and manage the video in the same exact manner as IP or HD Over Coax cameras. Using the analog-ready bridges is a cost-effective solution for customers who want to upgrade their video surveillance system while still using their existing analog cameras. Get in contact with our Sales for more infos about the Analog Bridges!
| Make | Model | Known Issues | Camera Features | Audio | Preview Resolution | Video Resolution | Minimum Firmware | Support Date | Notes | Support URL |
| Dahua | DHI-XVR7108 | Must use custom firmware for HD-CVI support. Not available in USA. | HD-CVI 8 Channel Encoder | No | cif | cif,std,high,1080P | 3.218.0002.1., Build Date 2017-12-29 | 2018-12-19 | Appears as a multi-view camera. Add each view as a separate camera. | |
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-6704HUHI-K | Must use custom firmware for HD-TVI support. | Mutli-View encoder 4 streams, HD-TVI 4 Channel encoder | No | cif | cif,std,high,1080P,3MP,4MP,5MP | V3.5.20, build 180202 | 2018-03-04 | Available Preconfigured. | |
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-6708HUHI-K | Must use custom firmware for HD-TVI support. | Mutli-View encoder 8 streams, HD-TVI 8 Channel encoder | No | cif | cif,std,high,1080P,3MP,4MP,5MP | V3.5.20, build 180228 | 2018-04-05 | Available Preconfigured | |
| Hikvision | DS-6708HWI | Must use custom firmware for HD-TVI support. | Mutli-View encoder 8 streams,HD TVI 8 Channel encoder | No | cif | cif,std,high,1080P,3MP,4MP,5MP | V1.2.5, build 151123 | 2017-06-21 | ||
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-6716HUHI-K | Must use custom firmware for HD-TVI support. | Mutli-View encoder 16 streams, HD-TVI 16 Channel Encoder | No | cif | cif,std,high,1080P,3MP,4MP,5MP | V3.5.20, build 180202 | 2018-03-10 | Available Preconfigured | |
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-7204HQI-K1/P | Must use custom firmware for HD-TVI support. | Mutli-View DVR 4 streams,HD-TVI 4 Channel Encoder | No | cif | cif,std,high,1080P | V3.5.30, build 180404 | 2018-05-11 | Available Preconfigured. Disable POC for non-Hikvision TVI cameras. | |
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-7204HUHI-K1/FP | Must use custom firmware for HD-TVI support. | Mutli-View dvr 4 streams,HD TVI 4 Channel DVR | No | cif | cif,std,high,1080P | V3.5.51, build 180824 | 2019-02-07 | Disable POC for non-Hikvision TVI cameras. | |
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-7208HQI | Must use custom firmware for HD-TVI support. | Mutli-View DVR 4 streams,HD-TVI 4 Channel Encoder | No | cif | cif,std,high,1080P | V3.5.30, build 180404 | 2018-05-19 | Available Preconfigured | |
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-7216HUI-K2 | Must use custom firmware for HD-TVI support. | Mutli-View DVR 16 streams,HD-TVI 16 Channel Encoder | No | cif | cif,std,high,1080P | V3.5.30, build 180404 | 2018-06-03 | Available Preconfigured | |
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-7216HQI-K2 | Must use custom firmware for HD-TVI support. | Mutli-View DVR 16 streams,HD-TVI 16 Channel Encoder | No | cif | cif,std,high,1080P | V3.5.30, build 180404 | 2018-06-03 | ||
| Hikvision | DS-7A08HQHI-K1 | Must use custom firmware for HD-TVI support. | Mutli-View dvr 8 streams,HD TVI 8 Channel DVR | No | cif | cif,std,high,1080P | V3.5.30, build 180404 | 2018-10-12 | ||
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-7B04HUHI-K1 | Must use custom firmware for HD-TVI support. | Mutli-View dvr 4 streams,HD TVI 4 Channel DVR | No | cif | cif,std,high,1080P | V3.5.30, build 180404 | 2018-09-20 | ||
| Hangzhou Hikvision Digital Technology Co., Ltd | DS-7B08HQHI | Must use custom firmware for HD-TVI support. | Mutli-View dvr 8 streams,HD TVI 8 Channel DVR | No | cif | cif,std,high,1080P | V3.5.30, build 180404 | 2018-09-30 |
