I am posting this here for those that might be interested. Most here are probably well versed in this. But for those that aren’t yet, you might want to paste this in the comment box and see if you like it. It gives some good information on the camera. This is for a dual cam setup. But it will work on a mono. Hope this helps someone.
^Tn F
Frame Rate $(IMG.FRJ) ^hm
L^IL/R^IR
L$(SEN.ILL)/R$(SEN.ILR)
L-Exp ^El R-Exp ^Er
Size:(IMG.XTO) X (IMG.YTO)
(you might want to take out the line spaces. I had to add them to get it to display correctly on this message board)
