Webbased Mobotix S16b livestream
Hi,
I’m trying to create a livestream using the mobotix S16b.
The problem is, even if i connect directly to the camera using ‘http://<CAM_IP>/control/faststream.jpg?stream=full’ in VLC. I already encouter a delay of 5 seconds. This must be 2.5 or lower, Is there a solution to shorten the delay? I already tried altering the framerate, resolution and microphone quality to possibly lower the bitrate.
Another problem is that I am looking for a webplayer which supports the MxPEG or G.711U Codecs/protocols. I don’t want to transcode because this can cause delays.
