I have a problem: When I open the camera adress([url] http://86.127.212.113/cgi-bin/faststream.jpg?[/url]), it buffers for 30 seconds - 1 minute, play something fast and then buffer again. It does the same with all mobotix cams.
Take a look here: [url]https://drive.google.com/open?id=1iOB_ISq59Xj9kMNeaT_Vx9awo41gpSQw[/url]
Hi Andrei,
as shown in your video you are using the faststream with the mpeg codec by using “stream=full”
maybe you can use the MxPeg Codec for a better result:
- Check your Preferences in VLC like this in Tools/Preferences:
- Open your stream again with stream=mxpeg
Thanks. Now it works fine.
And is there another codec that is better supported?
