Hi,
I use a C26b night as a smart sensor. It has an IR ring to illuminate the room when completely dark.
But I encountered another inconvenient problem: All lighting in the room is LED which is driven by PWM dimming. This means the frequency does not match 50Hz or 60Hz. The DMX controlled lighting has a PWM freq. of 123Hz. 60Hz does give a lot less flickering and rolling than 50Hz (the default in the EU). But still I notice that detections both using MxMotion or plain motion are triggered by the rolling image and flickering lighting.
When in the config of the cam, only none, 50Hz or 60Hz can be chosen. Will the camera adapt other values when I change it in the manual config file? (123Hz for example, or 61,5 maybe…)
Thanks!
