ASSA ABLOY ARX Access Control Integration - Seamlessly integrate with MOBOTIX HUB Access
This integration is made up of a MOBOTIX HUB Event Server plug-in that communicates with ARX control unit via the ARX Server. The machine running the MOBOTIX HUB Event Server connects to the ARX Server using TCP/IP communication. Useful information is logged in Audit logs of the MOBOTIX HUB Management Client.
Plug-in configuration takes place in the MOBOTIX HUB Management Client, where users can:
- Add the ARX system
- Set properties
- Create Alarms and Rules
With MOBOTIX HUB Desk Client integration, users can:
- Add ARX system doors as an access monitor for live event monitoring
- Add ARX system actions as overlay buttons
- Control, monitor and create visual representations of ARX system doors via a map feature
- Gain a centralized overview of events/doors/cardholders in the access control tab
- Receive Access request notifications
Key features
- Use events generated by doors from the ASSA ABLOY ARX access control system as sources for alarms and rules in MOBOTIX HUB.
- Monitor events live in MOBOTIX HUB based on door access points and cameras.
- Control and status-monitor doors from MOBOTIX HUB. Get a clear overview by creating a visual representation.
- Integrate ASSA ABLOY ARX access control system badge holders into MOBOTIX HUB.
What is needed to integrate the plug-in:
How it works:
Access request
Event - Access card has an invalid format
Overlay buttons
Access Monitor
How to install the plug-in:
- Start the installation by executing AssaAbloyAccessControl_1.0.XX.X.msi.
- Click Next
- Read the license agreement carefully and select I accept the terms in the License
Agreement box. Click Next - Click Install
- The next steps are executed automatically.
- Click Finish.
- Restart the MOBOTIX HUB Event Server and the MOBOTIX HUB Management Client
Ordering the required MOBOTIX HUB licences
The licence for MOBOTIX HUB Access (Mx-HUB-ACS-BASE) and the required device licences for the access points (Door licence Mx-HUB-ACS-DOOR) can be ordered via the MOBOTIX sales channel:
Order number: Mx-HUB-ACS-BASE and Mx-HUB-ACS-DOOR
Ask our sales department sales@mobotix.com
- Request a trial version: sales@mobotix.com
- Contact MOBOTIX: sales@mobotix.com
- MOBOTIX HUB version used at the time of testing: 2024 R2
- Milestone ASSA ABLOY ARX Access Control Integration Version: 1.0.45.1
Technical data sheet / instructions:
Milestone provides instructions for installation and configuration. The configuration steps described are identical when using the MOBOTIX HUB.
Milestone_ASSA_ABLOY_ARX_ACI_v1.0 (2).pdf (1.6 MB)
Download the plugin:
AssaAbloyAccessControl.zip (9.5 MB)
