Genea Access Control Integration - Associate Access logs and users to video in MOBOTIX HUB.
Access Control is the most widely used solution across corporates to restrict unauthorized access for outsiders. However, despite having installed high-end access control systems, it is often encountered that there is a security breach. Therefore, an integrated security system is required. For example, there are instances wherein an authorized person swipes for access, and an unauthorized person walks alongside him to enter the premises without proving his identity. In yet another scenario, people often forget to shut the doors after them, leaving the entire building vulnerable to outsiders. In absence of a system to provide visual evidence, it is impossible to identify the culprit even after the breach. Genea ACS integration with MOBOTIX VMS, ensures foolproof security of your organization, preventing unauthorized access.
Key features
- Correlate Video with Access Control Events - Admins can correlate their video feed with events and activities from our access control systems.
- Mapping doors and cameras together having a one-click view to video.
- More thorough, straightforward post-incident investigations, as you have video information linked to each entry/exit event.
- Lock and Unlock doors directly from MOBOTIX HUB
- Provide Quick Door access without switching to multiple platforms.
Requirements for using it
Function overview
Access control logs of the Genea system can be seen in MOBOTIX HUB.
Genea Access Control users can be associated with cardholders in MOBOTIX HUB
Users can watch live camera feed for the cameras connected to the door. Doors can be unlocked and locked without having to use another programm.
Where to associated doors from Genea Access Control to cameras in MOBOTIX HUB.
How to install Genea Access Control plug-in
1st step: Enable MOBOTIX HUB Integration on Genea ACS
- Navigate to the ‘Integrations’ tab in your admin dashboard.
Go to ‘Cameras’ integrations, and click ‘Install’ under the MOBOTIX HUB integration
Copy the Location UUID and integration token aka API key and save it to a notepad. We will need this information while setting up the Access Control integration to MOBOTIX HUB Management Client. Click enable to start the integration for the location.
Download and extract the plugin folder
2nd step: MOBOTIX HUB Management Client Configuration
Transfer the extracted plugin folder to the system where your MOBOTIX Event Server is installed. Place the folder in the MOBOTIX installation directory under MIPPlugins. The default path is normally C:/Program File/Milestone/MIPPlugins
Connect to your MOBOTIX HUB Management Client with admin credentials.
Locate the Access Control module in your MOBOTIX Site Navigation
Right-click and select “Create New” to start adding the Genea plugin
Enter the name of the integration, select integration plugin which you earlier saved in MIPPlugins folder in the
MOBOTIX Event Server installation directory. Enter the API key and Location Id that you have saved earlier from your Genea integration page. Once all details are filled in, click “Next”.
- It will fetch all the required information like doors, commands for remote operations, event states, etc. from your Genea application to MOBOTIX.
- Next step would be to map your access doors with the cameras. Simply drag and drop the cameras for each door in the list and click “Next”. Once the configuration is done and all your doors are mapped with corresponding cameras, you are ready to start monitoring the access events with the MOBOTIX Video Management System.
Now the plug-in is installed.
