Can't change recording frequency in continuous mode
Hello,
I am using a Mx-S15 in continuous recording mode and I am saving images using NFS.
I get one image every ten seconds and the parameter “Continuous Recording Frame Rate” has no effect on it.
I have checked that the parameter has an impact on streamframerate100 in configuration file. Please find the selected section of my config file below.
SECTION eventdlite
# generated by recording on 2019-10-21 17:21:16
recording_activ=enable
recording_timetable=
rec_sign=0
recsymbol=enable
freezeactiv=off
freezeevents=SIG,UC
freezedelay=15
recording=streaming
storypacking=0
streamframerate100=100
streamaudio=audio
recstartevents=*
storyinterval=1000
storyantecount=1
storypostcount=2
streameventframerate100=0
streamantetime=2
streamtime=10
recstretchevents=~
recstopevents=~
storystopcount=1
streamstoptime=10
recstopdeadtime=5
rechistory_sec=0
rechistory_cron=* * * * *
rechistory_interval=10
rechistory_imgprof=
recording_fullimage=0
edactiv=enable
edacttimetable=
armcond_ac1_source=disable
armcond_ac1_timetable=
armcond_ac1_illu_level=100.0
armcond_ac1_illu_src=right
armcond_ac1_illu_cmp=higher
armcond_ac1_illu_delay=10
armcond_ac2_source=disable
armcond_ac2_timetable=
armcond_ac2_illu_level=100.0
armcond_ac2_illu_src=right
armcond_ac2_illu_cmp=higher
armcond_ac2_illu_delay=10
armcond_ac3_source=disable
armcond_ac3_timetable=
armcond_ac3_illu_level=100.0
armcond_ac3_illu_src=right
armcond_ac3_illu_cmp=higher
armcond_ac3_illu_delay=10
armcond_ac4_source=disable
armcond_ac4_timetable=
armcond_ac4_illu_level=100.0
armcond_ac4_illu_src=right
armcond_ac4_illu_cmp=higher
armcond_ac4_illu_delay=10
armcond_ac5_source=disable
armcond_ac5_timetable=
armcond_ac5_illu_level=100.0
armcond_ac5_illu_src=right
armcond_ac5_illu_cmp=higher
armcond_ac5_illu_delay=10
armcond_acl_source=disable
enable_distributed_camera_state=0
master_cam=
replication_protocol_port=60000
led_events=~
led_arming=edactiv
inputarm_delay=60
inputdisarm_delay=0
motionhideunused=0
motionwintype=highlight
motionwinid=1
motionreftime=0
motionnightoff=0
motion_area=0,540,380,200,200,s=20,a=25,id=1%0A0,140,330,200,300,s=20,a=25,id=2,col=blue%0A0,940,330,200,300,s=20,a=25,id=3,col=blue
ima_as_fast_motion_stabilizer=0
ima_as_noise_improvement=0
ima_as_show_directions=1
ima_as_show_position=0
ima_as_show_profile=
ima_as_use_v2=0
ima_as_use_perspective=0
ima_as_near_obj_size=
ima_as_far_obj_size=
ima_as_min_obj_size=
motioncopydyni=1
motioncopyoffsetx=0
motioncopyoffsety=0
motionduallens=0
motioneditdef=0
ipreceiveport=8000
softbutton1=1
softbuttonname1=Speak IP
softbutton2=0
softbuttonname2=Actions disable
armcond_ac1_signalin_which=
armcond_ac1_signalin_state=si_open
armcond_ac2_signalin_which=
armcond_ac2_signalin_state=si_open
armcond_ac3_signalin_which=
armcond_ac3_signalin_state=si_open
armcond_ac4_signalin_which=
armcond_ac4_signalin_state=si_open
armcond_ac5_signalin_which=
armcond_ac5_signalin_state=si_open
led_event_signaling=1
recording_logic=and
recsuspectevents=~
recsuspecttimepre=10
recsuspecttimepost=10
imageinfo=1
chartdrawmode=off
chartevent=ENV,PI
objecttracing=disable
objectcamera=auto
ENDSECTION eventdlite
SECTION eventrecorder.json
   "activated" : true
ENDSECTION eventrecorder.json
SECTION events
# generated by control:event_sig on 2019-10-21 16:54:11
sig=SI:_profilename=SI:_profilestate=i:sig_sens=si:si_pin=ob,1
sig=UC:_profilename=UC:sig_sens=uc
sig=SB_Arm_Record_UC:sig_sens=uc
ima=VM:_profilename=VM:ima_sens=vm:vm_list=1
ima=VM2:_profilename=VM2:_profilestate=i:ima_sens=vm:vm_list=2,3
ima=AS:_profilename=AS:ima_sens=as:activity_level=33:activity_area=0,0,0,1280,960:activity_directions=Left;Right;Up;Down
ima=SB_Arm_Record_VM:ima_sens=vm:vm_list=
ima=SB_Arm_Record_AS:ima_sens=as:activity_level=33:activity_area=0,0,0,1280,960:activity_directions=Left;Right;Up;Down
env=PI:_profilename=PI:_profilestate=i:env_sens=ir
env=MI:_profilename=MI:_profilestate=i:env_sens=mi
tim=PE:_profilename=PE:_profilestate=i:tim_sens=pe
tim=TT:_profilename=TT:_profilestate=i:tim_sens=tt:timerunit=sec:timer=60:tim_dead=5:randomrange=1.000:tt_crondef=*/10 * * * *
ENDSECTION events
Thanks
Looks like the frames you’re getting are from history recording. If you don’t need the history recording, then disable it to help debugging your real problem.
Regards,
Amin /LMCS
