How to configure a Continous Recording in the MOBOTIX HUB
Normally, the MxHub is designed to trigger a recording when an event occurs.
However, there is a possibility to start a continuous recording as well
To implement continuous recording in the MxHub, you must proceed as follows.
You only need to set up a rule that specifies the continuous recording.
To do this, create a new rule under:
→ Rules and Events
→ Rules
=> Right click - Add Rule…
Name it: Continuous recording
  • In the first step select "Perform an action in a time interval"
→ Click: Next
  • Now select "Allways"
    (you can also select a time profile to set the continous recording only on a specific time range)
→ Click: Next
  • Now select "Start recording on < devices > "
Now click on "recording device"
4
  • Now select which of the cameras should perform continuous recording and click on Add
    → OK
→ Click Next 3 times
Now the Rule for Continous Recording has been created.
→ Click Finish
