Conexao O-Insights BACnet plugin for MOBOTIX HUB EN
O-Insights™ BACnet plugin - The plugin allows two way communication of MOBOTIX HUB with all the leading BMS/SCADA systems.
O-Insights BACnet tool enables two-way communication over BACnet between systems including building management, smart grids, SCADA and MOBOTIX HUB VMS. The plugin is integrated, tested and implemented with all the leading BMS systems in the market.
Key features
  • Send critical security information to BMS Systems over BACnet
  • Alerts using SMS, Email, Phone, Mobile App notifications.
  • Get alarms from BMS systems into MOBOTIX HUB for action
  • Easy Installation and Configuration and Resource-light app. Can be customized to send custom events over BACnet.
  • Tight Integration with Tridium Niagara
  • MOBOTIX HUB
  • O-Insights BACnet Plugin
How it works:
MOBOTIX HUB alarm/events over BACnet
SCADA (Niagara in the SS, or any other SCADA will work) shows the camera status/alarm over BACnet
O-Insights Plugin Configuration
How to install the plugin:
  1. Open the Setup and after reading the License Agreement, click accept and click next.
  2. Select the directory where you want to install O-Insights and click next.
  3. Post installation click finish. You can start O-Insights from the installed directory or the desktop shortcut.
Datasheet:
MOBOTIX HUB BACnet Datasheet.pdf (2.8 MB)
