EIZO Video Wall Plugin for MOBOTIX HUB
EIZO Video Wall Plugin is a plugin for managing IP decoding monitors and box solutions
Overview
EIZO Video Wall Plugin is a plugin for managing IP decoding monitors and box solutions through MOBOTIX HUB VMS. The plugin provides full integration with the VMS. Compatible products are DuraVision FDF2712W-IP, FDF2312W-IP, and DX0212-IP.
Key features
- Centrally manage IP monitors and boxes on the network from the VMS.
- Build a video wall with multiple IP monitors and boxes to display camera streams.
- Simultaneously display multiple streams on each IP monitor/box. Choose from several default layouts in the VMS.
- Supports DuraVision FDF2312W-IP (27-inch monitor), FDF2312W-IP (23-inch monitor), and DX0212-IP (box).
What is needed
- EIZO Video Wall Plugin
- EIZO DuraVision (FDF271W-IP / FDF2312W-IP)
- EIZO DURAVISION DX0212-IP
- MOBOTIX HUB VMS
- MOBOTIX HUB ONVIF Bridge
How it works
EIZO´s lineup includes 23 and 27-inch monitors as well as external box solutions. Each are fully integrated with MOBOTIX HUB.
EIZOS´s decoding solutions can be controlled and monitored directly from the VMS interface including camera registration, remote status checks, and adjustments to the video layout and display.
Video feeds of registered cameras can be conveniently dragged and dropped to the desired position.
The views of the remote EIZO monitors can be selected quickly and easily in the MOBOTIX HUB Desk Client.
The administrator can flexibly create view layouts as presets and layouts in the Management Client.
MOBOTIX Field Engineer has tested the Solution with:
- MOBOTIX HUB 2025 R1
- EIZO Plugin Version 1.1.1.0
How to install
Download of the PlugIn:
https://www.eizoglobal.com/support/db/products/software/search?k=milestone&x=37&y=13
