Let’s suppose we want to enable/disable the app Vaxtor based on some event such as illumination…
So the IP notification will be the following:
A. From Admin → Edit, We shall search for the correct path for the App, as following…
In our case will be:
camera/plugin_manager/plugins/VaxALPR/active
True ->> will be the parameter message used in the JSON Data Type while Creating the IP-Notify Profile…
From Admin Menu → IP Notify Profiles.
- Create a Profile for VAX AppON as following
Parameters will be:
IP Notify Type: HTTP/ HTTPS
Destination Address: Localhost / Parallel send to all
HTTP Method: Post
CGI-Path: /api/json/config/camera/plugin_manager/plugins/VaxALPR/active
Security / HTTP Schema: HTTPS
Authentication method: Your camera password
Notification Data: JSON
Message: True
Port Number: 0
- Create a Profile for VAX AppOff as following:
Parameters will similar to the above profile except changing the Message to " false ".
B. From Setup Menu → Text & Display Settings to show the Lux value on the live image…
Parameters are : $(SEN.LXR), $(SEN.LXL)
C. From Setup Menu → Event Overview → Environment Events, To create the Illumination" Lux " profiles. Configuration will be as following:
->> To disable the app if the illumination lower than value 5 for example…
->> To enable the app if the illumination higher than value 5 as well…
D. From Setup Menu → Action Group Overview, to Create Action Groups for trigger the events created…
We will Create 2 profile as following…
1 ->> Create Vax APP On profile…
Then select the action is IP-Notify Vax/on
2 ->> Create Vax APP off profile
Then select the action is IP-Notify Vax/off
P.S: Certified App Settings Arming Shall be active, To Activate navigate to setup Menu → Certified App Settings
