In the below example, we will explain how to send variables from Apps ( in this case with Vaxtor LPR) via Ip-Notify using RAW TCP/IP.
This feature is available since firmware 7.3.1 using the following workaround via Events->Action->IPNotify Profile
- enable Vaxtor App and Enable MxMessage
- copy JSON Template in Reporting section also to MxMessage Template
Note 1 : do not use $image$ in template. IP Notify will truncate the messages after around 800 bytes.
Note 2 : You can find more variables here : Vaxtor ALPR ADR - Available variables to customize MxMessages / 3rd Party reporting - MOBOTIX 7 Certified Apps / Vaxtor Apps - MOBOTIX Community
- add IP Notify profile in Admin Menu > IP Notify Profiles
- Type: custom configuration
- enter designated destination address and port
- Data protocol: Raw TCP/IP
- Data Type: Plain Text (<-- important, not JSON)
- Message:
$(MSG.LOC.VaxALPR.custom)
Open Setup Menu > Event Profile > Message Events
- Adjust Dead Time and validate Filter Message Content set to No Filter
Add new Action Group in Setup Menu > Action Groups
- select Message: VaxALPR event
- adjust action dead time
- add new action and select your IP Notify profile
Close + Store everything
