In this article you will learn how to install Mobotix Hub on your Windows PC.
For this, a few system requirements must be given in advance, which you can see in the following article.
Note: The PC hostname and the Windows user name must be different, otherwise an error may occur during installation!!!
- Microsoft .NET Framwork 4.7 or higher should be installed on all PCs
We recommend additionally deactivating the following components before starting the installation
- AntiVirus Software
- Windows Defender
1. Start the Installation File with Admin Rights
=> Right Click on the Installation File → Run as administrator
Click on Yes
2. Select the preferred language for the installation
Note: This language setting at this point is only for the installation process
Click Continue
3. Accept the MOBOTIX license agreement
Click Continue
4. Select your license file
Click on Browse
Select your license which you received from your reseller
Click Open
Click Continue
5. Choose your Installation Type
Select Single computer
6. Choose the components which you need in your installation
Click Continue
7. Set a configuration password
=>If you do not set a password, any user can make changes in the ManagementClient. We recommend here to secure the system with a password
Click Continue
8. Select the specific recording server settings
Click Continue
9. Select the encryption when needed
Here you can choose several certificates to encyrpt the communication
Select your certificates or clicl directly on Continue
10. Select the file location and the product language
Here you can decide where the MxHub should be installed and what default language it should have.
Click Install
Depending on the system performance the installation may take some time
11. Installation finished
Click Continue
12. Add Usernamen and Passwort of your cameras
=> Now you have the possibility to add cameras to your system, add your camera credentials into the fields
=> However, you also have the option to do this afterwards in the ManagementClient, if you do not want to add cameras in this step, do not fill anything and click Close
13. Select and add the Cameras to your system
=> If you decided to add cameras already, you will see a list of found cameras and you can select them
Click Continue
14. Configure your devices
=> Here you can set a useful name for the camera
Click Continue
15. Add Users
=> Here you can add new Users to the system (Windows Users or Basic Users, you can do this also later in the ManagementClient
Add new Users or click directly Continue to do this later
16. Configuration completed
=> Here you can see an overview of which cameras has been added to the system
Click Close
17. Install the latest Device Driver Package
To make sure that the MxHub has the latest and most up-to-date camera drivers, the device driver package should be installed after the successful installation of the MxHub.
After the installation finished you should have 2 Shortcuts in your Desktop
By clicking in HUB ManagementClient 2020R3 you can start to configure your system
