It is possible to automate the switching of Start Recording Events based on time using IP Notify profiles and Time Task.
Here’s how -
(for this example the customer asked how to start recording with AS and VM Events only between 06:00 and 17:00 and, with button push (doorbell) 24/7. I use the UC Event in this example in place of the doorbell)
-> Set up two IP Notify profiles under >Admin >Transfer Profiles >IP Notify Profiles
First profile for Start Recording Events AS, VM, and UC
Name the profile: (e.g. IP-Notify AS_VM_UC)
Destination Address: localhost:80
Data Protocol/Transfer protocol HTTP/1.0 Request
Data Protocol/CGI Path: /control/control
Data Protocol/HTTP Authentication: loginname:password
Data Type/Notification Data: plain text
Data Type/Message: set§ion=recording&recording_activ=enable&recording=streaming_event&recstartevents=IMA,AS;IMA,VM;SIG,UC
Second profile will be for Start Recording Events UC
Name the profile: (e.g. IP-Notify UC)
Data Protocol/Transfer protocol HTTP/1.0Request
Data Type/Message: set§ion=recording&recording_activ=enable&recording=streaming_event&recstartevents=SIG,UC
Both of these commands can be sent to the camera from a web browser for testing using the url -
The full list of parameters available can be found in the help file of the camera under Remote-Controlling the MOBOTIX Camera.
Set, Close and Ok to save the settings
Set up two Time Tasks
Go to >Admin >Camera Administration >Time Tasks
The first Time Task is to set Start Recording Events AS, VM, and UC using the IP-Notify profile created above.
Use the pull down to select the IP notify profile for IP-Notify AS_VM_UC
Set the time to send as -
0 Minutes
6 Hours
- Days of Month
- Months
- Week Days
The second Time Task is to set Start Recording Events UC using the IP-Notify profile created above.
Use the pull down to select the IP notify profile for IP-Notify UC
0 Minutes
17 Hours
- Days of Month
- Months
- Week Days
Es ist möglich, das Umschalten von „Start Recording“-Ereignissen zeitgesteuert mithilfe von IP-Notify-Profilen und „Time Task“ zu automatisieren.
So geht’s –
(In diesem Beispiel fragte der Kunde, wie man die Aufzeichnung bei AS- und VM-Ereignissen nur zwischen 06:00 und 17:00 Uhr und bei Tastendruck (Türklingel) rund um die Uhr starten kann. In diesem Beispiel verwende ich das UC-Ereignis anstelle der Türklingel)
Richten Sie zwei IP-Notify-Profile unter >Admin >Übertragungsprofile >IP-Notify-Profile ein.
Erstes Profil für die Aufzeichnungsauslöser AS, VM und UC
Benennen Sie das Profil: (z. B. IP-Notify AS_VM_UC)
Zieladresse: localhost:80
Datenprotokoll/Übertragungsprotokoll: HTTP/1.0-Anfrage
Datenprotokoll/CGI-Pfad: /control/control
Datenprotokoll/HTTP-Authentifizierung: Benutzername:Passwort
Datentyp/Benachrichtigungsdaten: Klartext
Datentyp/Nachricht: set§ion=recording&recording_activ=enable&recording=streaming_event&recstartevents=IMA,AS;IMA,VM;SIG,UC
Das zweite Profil dient für „Aufnahme von UC-Ereignissen starten“
Profil benennen: (z. B. IP-Notify UC)
Datentyp/Nachricht: set§ion=recording&recording_activ=enable&recording=streaming_event&recstartevents=SIG,UC
Beide Befehle können zu Testzwecken über einen Webbrowser unter folgender URL an die Kamera gesendet werden:
Die vollständige Liste der verfügbaren Parameter finden Sie in der Hilfedatei der Kamera unter „Fernsteuerung der MOBOTIX-Kamera“.
Auf „Set“, „Close“ und „Ok“ klicken, um die Einstellungen zu speichern
Richten Sie zwei Zeitaufgaben ein
Gehen Sie zu >Admin >Kamera-Verwaltung >Zeitaufgaben
Die erste Zeitaufgabe dient dazu, die Aufzeichnung von Ereignissen AS, VM und UC mithilfe des oben erstellten IP-Notify-Profils zu starten.
Wählen Sie über das Dropdown-Menü das IP-Notify-Profil für „IP-Notify AS_VM_UC“ aus.
Legen Sie den Zeitpunkt für den Versand fest als:
0 Minuten
6 Stunden
- Tage im Monat
- Monate
- Wochentage
Die zweite Zeitaufgabe dient dazu, die Aufzeichnung von Ereignissen für UC mithilfe des oben erstellten IP-Notify-Profils zu starten.
Wählen Sie über das Dropdown-Menü das IP-Notify-Profil für „IP-Notify UC“ aus.
Legen Sie den Zeitpunkt für den Versand fest auf:
0 Minuten
17 Stunden
- Tage des Monats
- Monate
- Wochentage
Klicken Sie auf „Festlegen“, „Schließen“ und „OK“, um die Einstellungen zu speichern.
